Unable to patch Techwood 55A)9UHD (Vestel mb230)
  • jimdhope
    • May 2021
    • England
    Hi there everyone
    I was wondering if I could get a little help. Back in November my wife and I bought a Techwood 55AO9UHD (running on the Vestel mb230 board) and it's been brilliant... except for one thing. We're unable to get the phone remote app to work.
    I've contacted Techwood's Support line and they have kindly provided me with a copy of the firmware that was meant to fix the issue... of course it did not. The Virtual Remote is turned on in the TV setting but it's not really making a difference.
    I also run a Home Assistant Server and though I'd try connecting through that instead. Turns out I can't do that either as the port 1986 isn't open.
    I've tried using the SwProfile_patcher_kurulumsuz to edit the firmware file but when I select the firmware to load into the app It become unresponsive and eats up all the Memory & CPU until I force quit the program (the longest I've left it running has been about an hour to see if time will hep but no dice)
    Is there another way for me to enable the port on the TV at all or another version of the patcher out there?
    Thanks for you help
    Jim
  • jimdhope
    • May 2021
    • England
    Re: Unable to patch Techwood 55A)9UHD (Vestel mb230)
    UPDATE: So I tried downloading a different firmware to see if it will work with the software (MB130) and all seems to go well so I'm wondering if it has something to do with the files. I noticed that the MB130 comes with 3 files (hwProfile.bin, LangProfile.bin & SwProfile.bin) whereas the mb230 Firmware is just one file (kylo_usb_update.bin).
    Does anyone know if there has been a patcher released that I can use to modify this file?
    • jimdhope
      • May 2021
      • England
      More Updates:
      I bet you all love me unintentionally spamming you all.
      So I've managed to get hold of the 3 profiles from the TV itself... why it didn't work before I have no idea. Whilst it turns out I can not access the profile the profile patcher doesn't have the option to enable the port and whilst I can get the files to load in the ToolBox I have not idea where to start.
      Any help would be greatly appreciated
      • Bazilwrc164
        Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
        by Bazilwrc164
        I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
        The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
        I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
        If anyone can provide:
        • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
        • Or a compatible EEPROM dump
        07-23-2025, 12:15 PM
      • massimomax
        Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
        by massimomax
        Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
        spero che qualcuno può averlo per riprogrammare eprom. grazie
        Post in English !!!
        I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
        02-28-2025, 07:27 AM
      • anlu
        Vestel Firmware - Toshiba 32W133DN
        by anlu
        Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
        Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
        02-04-2023, 12:59 AM
      • piernov
        Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
        by piernov
        Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
        I suspect corrupt firmware but I haven't been able to find anything for this TV.
        TV model: Finlux 65-FUC-8060
        Mainboard: Vestel 17MB130S 23473048
        Panel: VES650QNTS-2D-U11
        At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
        06-01-2024, 12:57 PM
      • TheUser
        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
        by TheUser
        Hello to everyone ,
        This is my first post here, and i would like to share with you a small story in case you can help me.
        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
        02-10-2024, 02:07 PM
