Sony KDL-52X3500 half "clearer" image
  • Ranmamez
    • May 2013
    • 19
    • Italy
    Hello.
    A friend gave me this old piece of behemoth (it "only" weighs 49 kg).
    The problem is as shown in the attachment: the right part is more clear than the left part.
    I guess that's the T-Con that's somekind faulty, I found lightly different voltages between the left lcd electronic board and the right one on the VDD and AVDD test points.
    The T-Con is a 404652HHC8LV1.8. Googling around I found that in this forum there's someone that already dealed with this same T-Con, but for a different problem (if I hadn't misunderstood). This is the thread I'm referring to: https://www.badcaps.net/forum/showthread.php?t=88259
    Can someone help me track down where's the possibly fault?
    Thanks!
  • Formaster
    Sony KD75XE9005 Bottom half double image
    by Formaster
    Hi guys,
    I'm tyred from these sympthom, if anyone helps me really big thx.
    When i open the connection and play with these ribbon cables, i can get back the image problem free. BUT after turn off and ON, the bottom half is ghosted/doubled again. Did'nt from touch, only reboot the TV. I have changed the ribbons from the other side, but the same. Anyone any idea please?...
    08-10-2021, 06:57 AM
  • domix
    Sony KD - 65XF9005 - No image, sound OK
    by domix
    at tv KD - 65XF9005 i have a problem.
    Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
    is this a common problem for this tv?
    i attached pictures of inside. Supply board looks okey, no blowed caps....
    07-21-2025, 06:37 AM
  • kevin.st56
    Sony KDL-40S4100 horizontal image tearing on right half of screen
    by kevin.st56
    hi all. i have a sony bravia 40in tv, the image on it will produce 3 horizontal lines, and the image overlaps itself, and itll happen when the tv has been turned off for some time. also, on rare occasion, there will be no image at all. with the tearing, it will eventually clear itself up when its been on for maybe 5-10 minutes, and all is good from there, until its turned off for a while, or power is removed. the lines are more noticable with darker images.
    a side note, there is also no standby light when the tv is off, but i havent been too concerned about it since the tv turns...
    05-15-2020, 09:03 AM
    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 02:20 PM
  • Dreamcazman
    Sony KV-XJ29M31 CRT TV - Very dim image on turn on
    by Dreamcazman
    Hi all, I recently picked up a Sony KV-XJ29M31 CRT TV (BG3R chassis, Australian model) cheaply & completed the RGB mux mod on it for some retro gaming. That worked great, however, I have another problem which I hope someone can help me with or at least steer me in the right direction.
    Basically, the issue is when it's cold, it takes a while (like 2 mins) for the picture to come up. I think the image is there, it's just very dark or dim. I can hear the degaussing sound & I can change inputs & hear audio but no image.
    Once it's running properly, it keeps...
    02-28-2022, 07:47 PM
