Samsung Ps60E6500 power board bn44-00513A
  • Alexsandu
    • May 2021
    • United Kingdom
    Hello everyone, I have a Samsung Ps60E6500euxxu plasma TV with a burned-out power supply. The power supply is model Bn44-00513A. Both fuses blown, 1 of the FDPF 12N50T is cracked (we bought new ones to replace them) and there is a transistor and some resistors that I can't identify. These are the problems I found after the visual check.
    I am looking for the diagram of this power supply board or if anyone knows the type of parts to be replaced
    Thank you in advance
  • R_J
    • 9588
    Re: Samsung Ps60E6500 power board bn44-00513A
    The components for QS804, gate drive should be the same. The resistor might be 22Ω. the diode could be KDS184
    • C152Heavy
      by C152Heavy
      Summary for TL-DR readers:
      • VCC pin (18) of PFC...
      01-11-2023, 02:53 PM
    • Destroyer-Br
      [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
      by Destroyer-Br
      I'm working on an Acer Nitro 5 unit with the following specs:
      • Motherboard: LA-J871P Rev: 1B
      • Model: Acer AN515-55-59MT
      • S/N: NHQ7JAL00403906A973400
      • SNID: 03902728734
      Initial Issue
      The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
      After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
      04-17-2025, 08:18 PM
    • Nicktronic
      Samsung Power Supply Board BN44-00874F
      by Nicktronic
      Hey everyone,
      This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
      Anybody...
      03-17-2025, 06:20 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
