kubo k1355vtstuhd backlight advice
  • pep2k21
    • Dec 2020
    • 35
    • Spain
    i dont find many info about this tv. not many replacent parts.
    i have one with backlight problem near, and im thinking about buying it to try to repair but i dont see replacement leds for this model.
    what would you do? i think has vestel main.
    i mean is a 4k 55" may be is worth to have a look or maybe is a problem to find replacemnt, as it looks like
    thank you
  • Diah
    • Feb 2013
    • 6614
    Re: kubo k1355vtstuhd backlight advice
    you need to answer this one by one
    1- do you hear sound ?
    2-did your TV response to remote control ?
    3- if you use torch light can you see the screen or menu when you call it ?
    4 and most important post clear photos on your TV boards and write here the mainboards label No.
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • cheebster
      iPad Pro 12.9 5th Gen Backlight Issue
      by cheebster
      Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
      Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
      Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
      The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
      Anyone...
      05-20-2025, 09:17 AM
    • canadaboy25
      LG Flatron 24EN33TA No Backlight When Cold
      by canadaboy25
      I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
      I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
      03-07-2023, 12:23 AM
    • triplefour
      TCL 75S421 has sound but no backlight not even a flash
      by triplefour
      TCL 75S421
      PSU BOARD: 40-L402H8-PWD1CG
      it shows not even a flash of backlight when powering up.
      but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
      testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
      unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
      i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
      with mb connected, PSON...
      11-17-2023, 09:54 PM
      by Vesko356
      08-11-2023, 03:27 AM
