Ps51d450
  • Jamesb79
    • Apr 2021
    Ps51d450
    Hi, Firstly I have learned a lot using this forum, I have an old PS51d450 it's been working perfect until last week, where it turned off and I had no picture or sound. Using this forum I discovered a short on the X main board, all other board test fine and giving me proper voltages across them. I replaced the x main last night and the TV works again. Picture is near perfect. But one thing I forgot to check was the VE voltage from the X Main test point. When I checked this I am only getting 86v from the VE test point on the X main but the ribbon cable coming from the Y main is giving it 100v which is close to what the panel sticker states 101v.
    Because the TV is working again, I have switched it back off incase it does any damage until I find out if I need to adjust the bottom pot so the VE test point on the X Main should be set to read 100v the same as the top and feed from the Y main. Also I noticed there is some amount of heat from the big heatsink on the left of the X main so much that after only 10 mins you can't keep your finger on the heatsink is this normal? I know to TV gave off a lot of heat before so this might be normal but thought I would ask. Thanks
  • R7027
    How to probe TP7002 for AP_PS_HOLD on SM-G930F?
    by R7027
    In the service manual for Galaxy S7 (SM-G930F), step number four in the flow chart for troubleshooting power-on issue is to check the voltage level of a "signal".
    I had a very hard time locating this. I didn't understand what it means to check for voltage of something by its signal name, and it's location was not described in the service manual (not that I could see in my four chapter excerpt of the complete manual). Then I learned that this signal name needs to be translated into a test point (TP) ID on the board. This is unlikely to be referenced in a service...
    01-02-2023, 06:25 AM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
  • SluggerB
    Help with trying to fix phone that is not charging (Pics inside)
    by SluggerB
    I have two TCL A30 phones.
    Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
    New Phone: Works fine, bought as a donor board to try and repair Old Phone
    My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
    08-12-2024, 08:11 AM
  • PlasMatt
    LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
    by PlasMatt
    I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
    09-20-2025, 06:50 PM
  • rmp4444
    Samsung 82" TU7000 with VPMS3SM
    by rmp4444
    Hi everyone, I am new to here,
    My friend gave me a dead 82” TU7000 with black screen. Backlight worked. I replaced it with a main board from a panel cracked 58” TU7000 and it did display but with vertical/horizontall lines. Therefore, it is for sure, the problem is on the mainboard.
    The main board came with VPMS3SM and at 58", it was VPMS3RT. Not much info found on these devices. The board had 3.3, 1.8, 1.9 as well as 12.8V which was from the power board. In this topic: Samsung LH50QETELGCXGO It told me that VPMS3SM was disabled and jumper is required to bypass...
    08-25-2025, 11:34 AM
