Sony KDL 46HX900
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    Sony KDL 46HX900
    Sony KDL 46HX900 with sharp led driverwill power on and work for some seconds then shutdown and blink for 6 times. I ckecked the the back light all is working fine. Am asking if there a way one can remove protection on this kind of led driver? I attaced thepicture of tv
  • kasfamily
    • Aug 2014
    • 770
    • Russia
    Re: Sony KDL 46HX900
    Hi!
    Try to disconnect 4 the panel loop from the t-con board
    • neilc6
      • Nov 2015
      • 1550
      Your TV is indicating it has bad backlights and they are likely failing under load. You can try turning down the backlight level and see if they stay on.
        How did you check each LED backlights strings? There are many LED strings on that panel based on many LED connectors on the driver board.
        • hispeck
          • Aug 2015
          • 258
          • nigeria
          I opend the panel to the backlight , and i can see All lighting . But after some few seconds it will shutdown . If i power it again the samething. So that is why i said led.strips are good . Though some may light like this.and still fail
          • hispeck
            • Aug 2015
            • 258
            • nigeria
            Ok i will try this and see
            • ademim
              • 28
              • Portugal
              Hi I have the same exact problem did you ever fix it???? Pleased reply
              • Storyteller12
                • Jun 2020
                • 624
                Replace backlights.
                4 and 6 blinks is backlight error codes
                • Carlos#2003%
                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                  by Carlos#2003%
                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                  02-15-2024, 07:52 PM
                • dkneyle
                  Sony KDL-46HX850 Can't upgrade/update firmware
                  by dkneyle
                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                  09-25-2024, 10:44 PM
                  Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                  This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 05:27 AM
                  Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                  This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                  09-06-2024, 05:30 AM
                  Sony VAIO Tap 11 Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                  This specification for the Sony VAIO Tap 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Tap 11 boardview and Tap 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
