Sharp LC-50P66U Power Cycling
  • packrat79
    • Mar 2017
    • 17
    This set was brought into my shop a few weeks ago, the power supply was totally dead. Customer said the set had hardly ever been used. I ordered a power supply from an eBay seller, after installing the set would power up just long enough to display the Sharp logo, then shut off, and keep repeating. The voltages to the mainboard (12 and 16VDC) remained steady, as did the P-ON signal to the power supply, but the BL-ON and DIM signals cycle along with the power. I was sure the mainboard must be faulty too (lightning strike maybe?, so I ordered one, installed it, and got the exact same result. The seller thought the board might be defective so I'm sending it back, but before I order anything else I thought I'd see if anyone has any ideas. I tried to access the service menu, but the typical procedures for Sharp TV's don't apply because this is a rebranded Hisense. And not surprisingly, there isn't any service info available for this set.
    Any ideas?
  • nomoresonys
    • 12206
    • U.S.
    Re: Sharp LC-50P66U Power Cycling
    Test the voltages at the connector on the powerboard with EVERYTHING hooked up, it's the connector that the cable from powerboard to mainboard hooks into, most times there's a legend/map nearby that gives the expected voltages, you measure them with your mutimeter, set meter to 20 vdc then report them, put neg probe on chassis metal ground, pos probe on pin of connector, measure in standby take note, leave probes where they are then power on tv and again take note of voltages, report them here, example pin 1-ps-on-0 volts standby-power on-3.3 volts.
    • packrat79
      • Mar 2017
      • 17
      Yes that is exactly what I did:
      Pin ID / V in standby / V powered
      12VDC 12 12 steady
      Vcc 16 16 steady
      P-ON 0 ~3.1 steady
      BL-ON 0 2.2 cycling
      DIM 0 2.2 cycling
      That's basically all there is on that connector, plus ground connections of course. The BL inverter (part of the power supply) does not send any feedback signal to the mainboard for detecting faults, something I have seen in older sets.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        What voltage (maximum) do you have at L925 and L926. Should be 200V
        • nomoresonys
          • 12206
          • U.S.
          Possible mainboard issue, the bl-on should be steady, see if the bl-on is steady on the mainboard side of the connector.
          • packrat79
            • Mar 2017
            • 17
            The BL-ON signal cycles on both sides of the connector. As unlikely as it seems, everything points to the mainboard. I guess I'll have to order another one and see what happens.
            • packrat79
              • Mar 2017
              • 17
              Got the set working. Another eBay seller advised me to check the backlights. They were not defective, but it occurred to me that this symptom was very similar to a backlight fault. It didn't make sense though, because it didn't look like there was any way for the mainboard to sense a backlight fault and shut down. However, I started comparing the two power supplies and discovered that some components (mostly resistors) had different values. I also noticed that although the part numbers on the boards matched, the sub-numbers on little stickers were slightly different. So I tried swapping all the components of different value from the old board, including the switching transformer, and the set powered and stayed on. Both boards had the exact same power output specs printed on them (which is what fooled me) but apparently they were not the same.
              Anyway, problem solved and lesson learned. Thanks anyway for your help.
              • nomoresonys
                • 12206
                • U.S.
                Right, thats why you match up the sticker numbers, NOT just the board numbers, many use the same board number but each can be populated in a different manner for their application.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • MyBrainIsAStrainer
                  Asrock H87-Pro4 Rev. G/A 1.04: Power cycling on reset only
                  by MyBrainIsAStrainer
                  Hi!
                  I have a weird one for you. I have a H87-Pro4 from Asrock that power cycles. But only when you do a restart after it was already running!
                  Symptoms in detail:
                  1. I switch off the ATX PSU for ~15-20 seconds, then switch it back on again.
                  2. I press power button. The board boots without issues.
                  3. I can shut down the board any way I want (via OS* menu, or pushing the power button - either in the OS or the boot manager).
                  4. Push power button again, board boots fine.
                  5. This shutdown/powerup can be repeated multiple times without problems.
                  6. BUT: If I do a restart instead
                  06-25-2023, 02:44 PM
                • mon2
                  A2141 820-01700 Power cycling (DFU worked ok)
                  by mon2
                  Hi. Working on an A2141 that is power cycling. Powers up fine (20V @ 3.1A peak) -> fan spins ok and then at a higher speed (after we removed the trackpad so the sensors are missing) -> chimes ok but after the high fan spin -> power cycles and repeats this loop. We did manage to DFU the unit with revive mode (4/4 steps completed ok) -> resulted in a brief padlock graphic before power cycling. Unable to toggle the keycaps led since the boot does not reach this far of the cycle.
                  Q: Does the DFU process validate that the nand flash is OK ? We do not wish to restore this board...
                  11-24-2023, 12:17 PM
                  03-31-2024, 02:12 PM
