LONG!! Feel free to skip to "AT LAST, The problem:"
This is yet another Craigslist special. When power is applied the relays click several times and the error LED starts flashing error code 12 - problem with the 12 volt supply. After pulling out over 50 screws, I was able to verify the 12V supply came up to only 6.8 volts. Time to pull the power supply.
This supply should be a testament to bad design. Not only are there caps adjacent to heat sinks, there are caps UNDER heat sinks. There are even a few that would require removing the heat sink to remove the cap. Of course, schematics are not available.
After tracing the 12V output back to it's source, I found it was a fairly simple design. Rectified and filtered line voltage is fed to a SMPS which drops it to about 13.5 volts (Vcc). Vcc supplies three loads - the Ambilight inverters (not present on this chassis), a bucking regulator to produce a 5.6V supply, and a low drop-out linear regulator to produce the 12 Volts. All caps in the Vcc supply and the 12V supply test good (ESR less than .05 ohm).
The 12 Volt regulator is a KIA378R12PI - a 12 volt, 3 amp regulator. This crosses to a Fairchild KA378R12C. This regulator is rated to work with as little as a .5V drop between input and output. Maximum power dissipation is 15 watts with a heat sink. The typical load in this set is 1.7 amps. It is used only on the small signal board as a supply for bucking regulators.
AT LAST, the problem: There are two possible explanations for the low output voltage - a failure in the regulator itself, or excessive load. There are no convenient jumpers to lift so the current draw can be checked. Does anyone have any suggestions for measuring the load? The regulator itself is available from Mouser at a very reasonable price (plus an unreasonable amount for shipping).
PlainBill
PlainBill
