Samsung UE46C800 Intermittent Vertical Bands
  • Anachronist
    • Feb 2021
    • 11
    • France
    Hi there,
    Our sterling UE46C8000 has recently come out of storage and has started intermittently exhibiting two vertical bands - one light, one dark - side-by-side to the left of the screen.
    Sources are through a receiver so only using one input on the TV. Changing inputs makes no difference.
    Often they will disappear on a scene change watching live material but with recorded material they'll stay until the input source is changed, or switched to menu/guide. Appears to be more prevalent with recorded material.
    No vertical bands on the self test.
    I can't find anything similar anywhere so if anyone's seen anything like this before I'd be very grateful to hear about it.
  • Diah
    • Feb 2013
    • 6361
    Re: Samsung UE46C800 Intermittent Vertical Bands
    as it was in storage.. no one know what happen at time there ... so you need to open it and clean inside.. take out all cable specially the LVDS cable ( the one between the mainboards and t-CON) clean them and put them back in place.
    • Anachronist
      • Feb 2021
      • 11
      • France
      OK, Back off, vac'd out. It was pretty clean inside but was stored sealed inside its box.
      All boards disconnected and inspected. No visible component damage or dry joints. Signs that mainboard and TCON board have got warm at some point - staining underneath both on the chassis.
      All sockets blown out with canned air and plugs/ribbons/grounds cleaned with isopropyl.
      Back together and.... banding is back after 5-10 minutes. Goes away switching between sources as before.
      What now - hunt for some boards or find somebody locally with an oscilloscope?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4316
        • Italy - Milan
        CLeaning totally unuseful in theese cases, you have problem with the specific source driver, locate the COF in corrispondence of the fault, then inspect the board attached to it, if there's no corrosion, then the cof is partially desoldered, must use soldering iron tip on to he back that is the side in front of you under the chip, must be put something rigid but not heat transmittant under it to be able to press it well..
        • Diah
          • Feb 2013
          • 6361
          1- try make hard reset from service menu, ( not reset from user menu setting )
          2-change the video output format of yours receiver.. 1080P if it was 1080i , or any other low resolution, let see at which resolution the line will not displaying.
          • Anachronist
            • Feb 2021
            • 11
            • France
            Forgive my ignorance but what's a COF and how do I identify which one is responsible?
            • Anachronist
              • Feb 2021
              • 11
              • France
              Factory reset from service menu done - makes no odds.
              Went through every resolution available:
              1080p - banding appears although interval appears longer
              720p and 576p - banding visible as very feint lines - only really visible against a dark background - and disappears with cuts/scene changes. Does appear as the light/dark pair eventually though.
              • Diah
                • Feb 2013
                • 6361
                can you show me please
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4316
                  • Italy - Milan
                  Cof is the chip on the flat cables between panel's board and panel you must heat under the chip, dont exagerate and heat especilly where the heat improves the picture ,yes you must do it with tv turned on.
                  • Anachronist
                    • Feb 2021
                    • 11
                    • France
                    Hard to photograph but here you go.
                    Interstingly just watched a dvd at 1080/24p without a single incidence in over 90 minutes....
                    • Diah
                      • Feb 2013
                      • 6361
                      ´then it sound the receiver caused this issue ... for more sure put mpeg movie 1080 on usb and play it.. if the set it owned player..
                      • Anachronist
                        • Feb 2021
                        • 11
                        • France
                        Don't think so. I've played material off the server using the BD straight in - still get bands.
                        I was interested in the fact it wasn't 50Hz.
                        • Anachronist
                          • Feb 2021
                          • 11
                          • France
                          Sounds terrifying... I'll investigate when I get some time off on Wednesday.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4316
                            • Italy - Milan
                            It's not terrifying, it's relatively an easy job instead, if it remains lets say a single line and it wont disappear, you can study a way to keep it pressed to bezel with shims, this is a delicate step, i was near the solution with mine, a millimeter to glory, and an incorrect shaped shim breaked in two the cof...
                            • Anachronist
                              • Feb 2021
                              • 11
                              • France
                              MP4 on memory stick played on native player on TV shows banding immediately.
                              Same File played via Bluray through receiver shows no bands for ~ 20 minutes.
                              • Anachronist
                                • Feb 2021
                                • 11
                                • France
                                locate the COF in corrispondence of the fault, then inspect the board attached to it.
                                You were right on the money - small amount of oxidation on the board which cleaned off with iso - vertical bands appear to have gone although I'm now left with a single-pixel vertical red line.
                                Appear to have a burnt out track feeding the ribbon at D22 so scratching my head for a way to jumper that as there's nothing on the ribbon side to solder to.
                                As an aside do you know of any resource to find TVs with common panels? New price for mine is around 1200€ which is insane so was thinking of trying to locate a second hand one and would be easier if I could widen the net....
                                Panel is an LTF460HQ03 or Samsung P/No BN07-00874A
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4316
                                  • Italy - Milan
                                  Buying a replacement screen in tv field is out of discussion, you can gently cut out partially the flat along the contacts to separate those two with traces corroded, bent it and solder a single filament each one with bare tin, it's non so difficult, it worths a try. For your info the corrosion is built by the screen washing with detergant..
                                  • Diah
                                    • Feb 2013
                                    • 6361
                                    good that you still have trace of the line at the boards area so its easy to fix if you have calm hand with good light source and standing magnifier.
                                    i face such 2 time before and i did fix it
                                    take very thin copper wire( take it out one line from any wire) put solder on yours IRON at the top and move the cable over the solder so it will cover with solder.
                                    solder it at the start line on the boards ( before the ribbon cable) and let it go straight over the line you want to repair. with plaster type make it fixed on the line..
                                    now the most important take any small straight screw driver ( such for mobile ) and heat the end of it, with calm hand placed it on the cable and push down smoothly it will mild down ribbon and stick on the line.
                                    • Anachronist
                                      • Feb 2021
                                      • 11
                                      • France
                                      Thanks gents.
                                      I'll dig out the magnifier at the weekend and have a go. I'll let you know what transpires....
                                        09-07-2024, 05:50 AM
                                      • C152Heavy
                                        by C152Heavy
                                        Summary for TL-DR readers:
                                        • VCC pin (18) of PFC...
                                        01-11-2023, 02:53 PM
                                      • JesusJones
                                        Samsung Plasma Intermittent Vertical Bars (repeatable) PN50B430
                                        by JesusJones
                                        Trash picked this plasma for parts and found it had some bad solder joints. It powered on after reworking most of the boards and seems like it may even work.
                                        The symptoms is, when showing a picture of bright (mostly white) intensity (within the affected area only) a vertical strip 2 3/4" wide will begin to fuzz out (just to the right of samsung logo, 16 3/8" from screen edge), and soon turns black (from top to bottom). Changing to a darker scene immediatley ater will cause the black stripe to fade back in (it fuzzes and clears up again) and it starts working just fine....
                                        04-13-2021, 01:45 PM
                                        09-06-2024, 11:40 PM
