LC-70C6500U 3 Slow Flashes and Fast Flash
  • Plurxtc1
    • Oct 2014
    • 136
    LC-70C6500U anyone have the service manual? First time I've seen this problem. Most of the time its 1 Slow and 1 Fast, which is an issue with the LEDs.
  • budwich
    • Jul 2015
    • 3097
    Re: LC-70C6500U 3 Slow Flashes and Fast Flash
    you can try the "standard" disconnect one tcon to panel cable at a time and see if anything happens / changes. You also might have to do a "force on" sequence to get the set to start depending on how the error has been set.
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      +1
      I have an LC-70C6600U here right now. Hold these buttons simultaneously and see if the TV turns on.
      Volume down
      Channel up
      Power
      You may have to hold these buttons down and plug the TV in at the same time to work. Try with it plugged in first. If it appears to turn on shine a bright flashlight upon the screen and see if you see any image in there.
      My 6600U had shorted Gate Driver ICs on the left side of the screen with the 1-1 error code.
      They call me......."threadkiller"
      • Caimano
        hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
        by Caimano
        MB G7AD-2G DAG7ADMB8D0 REV D
        Processor i5 8265U
        AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
        Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
        Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
        02-06-2024, 10:14 AM
      • ekozeko333
        by ekozeko333
        🧠 What I’ve Done So Far
        Flashed...
        06-21-2025, 02:48 AM
      • corrize
        Nikon D800 camera - flash don’t work and capacitor don’t charge
        by corrize
        Hello, I'm stuck in troubleshooting…
        The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
        In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
        When I press the flash button, it's detected by the system, flash icon appear on LDC display....
        10-01-2022, 10:02 AM
      • joblo37pam
        Sharp LC-80LE844U Blinks 2 slow, 5 fast
        by joblo37pam
        It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
        The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
        10-26-2023, 02:17 PM
      • Comp_Pro
        820-01949 Running Slow Fast Fan ASD Software Download?
        by Comp_Pro
        Hello all,
        I'm trying to repair this A2251 macbook pro. Board is 820-01949. The original issue was liquid damage which all cleaned up well and the board was not heavily damaged. Unfortunately after liquid damage cleaning the computer is running extremely slow and the fan is running at full speed. Even the cursor is lagging. Because of this I can't use the built in hardware diagnostic to give me a clue as to what is happening. Does anyone know if Apple Service Diagnostic software is available for this model? Any other clues which could help me out? Seems to me there is an issue with...
        11-30-2023, 05:33 PM
