Sceptre X505BV - Logo appears for 1 sec then backlight shuts off, LEDs tested good
  • events.b
    • Oct 2010
    • 36
    Hello, this TV currently has me stumped. As the title states, when I power on the unit, the backlight comes on for 1 second then shuts off. The TV is still on, and I can see the video if I shine a flashlight on the screen.
    Using the LED backlight tester I was able to confirm all LEDs are illuminating and seem to be working correctly when independently powered by this tester, so that leads me to believe there is something wrong with the power supply board.
    Perhaps the great minds here can help me figure it out, as I don't see any thing obviously wrong with it. The backlight circuit seems to be controlled by an op-amp (U14). The part number for this op-amp is 10358. The hot side of the board is controlled by a FAN7930C PFC controller. I have not found any shorts on either side so far and the capacitors look to be ok.
    The backlight circuit is located on the top left of the board (top view) or top right of the board (bottom view).
    Thank you for your time.
  • neilc6
    • Nov 2015
    • 1550
    Re: Sceptre X505BV - Logo appears for 1 sec then backlight shuts off, LEDs tested goo
    Your LED tester only puts out about 20mA while your TV runs at a couple hundred mA. You have intermittent LEDs in the string. Their voltages will be higher or lower or they may be slow to turn on. You can also record the flash and go frame by frame to see whats not lighting up.
    • events.b
      • Oct 2010
      • 36
      So, you think the tester is giving me a false negative? That's disappointing to hear that it is a flawed test. I will try your suggestion and record a video to see if that gives any clues, thanks for the tip.
        "Using the LED backlight tester I was able to confirm all LEDs are illuminating" Did you take apart the panel to see that all LED lights up?
        What Voltage does the LED tester show on the reading for each LED string?
        • events.b
          • Oct 2010
          • 36
          Yes, I did take the panel apart because I too initially suspected faulty LEDs. The tester was showing about 79 volts I think, on each array. The TV has two separate LED arrays, one on each side. I illuminated each array separately with the tester and they both showed the same voltage. This is what caused me to step back and second guess myself, because I would expect one array to have a different operating voltage if it had bad LEDs. Each and every LED did in fact come on, although not at full brightness like neilc6 mentioned due to the current limit of the tester.
            I see.
            So is the PFC boosted Voltage on the main cap staying at 380 ~ 400V after the LED shutdown?
            And how about the BL-ON and PWM dim or ADIM control signals? Are they still present when the LED shutdown?
            Bad LED can fail when driven at high current.
            When test LED with tester at small drive current the bad LED may cause the Voltage reading on the LED tester to not be stable, the Voltage may vary up and down.
            • events.b
              • Oct 2010
              • 36
              Hello, after the LED shutdown, the voltages are as follows:
              The 400V caps near the LED backlight connector are at 0.4V
              The signal labeled "BK" is 4.5V
              The signal labeled "ADJ" is 4.1V
              • events.b
                • Oct 2010
                • 36
                Update: One of the optoisolators for the backlight current feedback I found to be open circuit. I replaced the optoisolator but still no change. I suspect the op-amp that drives the optoisolator is also bad.
                • events.b
                  • Oct 2010
                  • 36
                  Update: The op-amp (U14) was also bad. After replacing this op-amp and the optoisolator, the TV is working again.
                  • tom_h
                    Sceptre X505BV, blue LED, no display
                    by tom_h
                    Hello all,
                    I have a Sceptre X505BV-FMDR8HJ1PE8 tv that had been gradually over time taking longer
                    and longer to come on, now it will no longer display any image. Original symptoms
                    are the red standby LED would turn to blue immediately when pressing the power on
                    button, but there would be a delay for the "SCEPTRE" image to appear on the screen
                    and backlight to come on. The delay kept getting longer, then it would go from blue
                    LED back to red. Then when I pressed the power on button again it would bring the
                    display up and work fine....
                    10-05-2023, 06:53 PM
                  • HootisTigglebits
                    Microsoft Surface 3 Laptop Displays Windows Logo Then Shuts Off.
                    by HootisTigglebits
                    When I press the power button the Windows logo appears for as few seconds then the laptop turns off. I cannot access BIOS. Anyone have any ideas how I might fix this?
                    15" Surface Pro 3 Laptop with i7
                    Model: 1872
                    11-18-2024, 11:23 PM
                  • Teban1306
                    [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                    by Teban1306
                    Hello everyone!
                    I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                    System Information:
                    • Model: Lenovo ThinkPad T14 Gen 1
                    • Machine Type: 20S1S4E600 (Intel i7 variant)
                    • Current BIOS: N2XET42W (1.33) - Latest version
                    • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                    What I'm trying to achieve:
                    Replace the default "LENOVO" boot logo with a custom image during POST.
                    🔧 What I've tried:
                    09-14-2025, 11:49 AM
                  • Pipolups
                    Corsair K70 LUX RGB dying LEDs
                    by Pipolups
                    Hi there !
                    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                    10-08-2024, 11:58 AM
                  • Verlengsnoer
                    Bios splash/logo change
                    by Verlengsnoer
                    at firs, i hope this is the right place to post my question.
                    Im looking for a tool to change the bios logo.
                    everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                    i know that HP has a build in option to change the splash logo.
                    but i want to change the manufacturer logo to an own logo.
                    I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                    10-28-2022, 09:52 AM
