Rear Projector High Voltage Safety
  • GeorgeLG
    • Jan 2021
    I am experienced in electronic design and repair, including high voltage tubes (500v) but I will be getting into my first failed television which is a rear projector. I see a lot of info on discharging the tube in a front view CRT but nothing on how to safely discharge the HV in a rear projector with the three CRT guns. Can somebody please point me in the right direction to learn how to safely work on my television (WS-65905)?
    Thank you,
    George
  • R_J
    • Jun 2012
    • 9628
    Re: Rear Projector High Voltage Safety
    There should be no need to discharge the crt's There anode caps are sealed with silicon to prevent arcing. If you need to remove the anode leads from the high voltage splitter, you can unplug them and short the anode lead to crt ground being careful not to touch the end of the lead.
    In most cases you should not need to remove them.
    What is the problem with the ptv? likely a convergence problem.
    • GeorgeLG
      • Jan 2021
      Thanks.
      For a few months now the video would get some horizontal black streaks through it and then the screen would go blank but the power on/off/remote function would still work so I still had some power supplies and logic. After being off for an hour it would go for another few weeks or months. I have not had time to deal before but its time now. Today when it went off something burned up and filled the room with burning wire/component smell. IOW the "blue smoke of shame". I have to go out of town so I cant look at it for a few days but the scene of the crime is going to be easy enough to find. I just won't know yet if that the cause or the effect until I start diagnosing it.
      George
      • DynaxSC
        Extreme High Current & Low Voltage Short Killer ??
        by DynaxSC
        Hi Folks
        I'm looking for a extreme high current short killer solution for a reasonable cost.
        I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
        After taking off the socket, the shorts dissappear again.
        The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
        10-15-2024, 10:13 AM
      • SoporteHR
        LG 42PQ30R TV power supply does not work high voltage. (Liteon PS-7411-1-LF Rev. 2.1
        by SoporteHR
        Greetings to all, I hope you are well.
        I consult you because I have a problem with this power source.
        The TV when it is connected to the electrical power turns on the blue light but does not give an image. the source is heard a hum.
        When I disconnect the power from the TV plates and power it up by itself, the hum goes away.
        I have the STB voltages of 5vdc. The microcontroller is powered with said voltage and the main board LED lights up.
        but not the 12v or 17v ones, nor the 300vdc high voltage voltages, nor the VS or VA....
        06-20-2023, 04:30 AM
      • harp
        high voltage high resistance marking resistor
        by harp
        Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
        08-26-2024, 01:42 PM
      • conghuyms
        MSI RX580 Vcore voltage is too high, please help me !!!
        by conghuyms
        I have an MSI Armor RX580 8GB V1.3 graphics card. Currently, all power rails are present, but the voltage supplied to the GPU Vcore, which should normally be around 0.9–1V, is measuring at 1.4–1.5V. The GPU gets very hot, and the MOSFETs supplying the Vcore phases are also extremely hot, with a noticeable whistling noise.
        I’ve already replaced the UP9505P controller IC with a new one, but the issue remains the same.
        Since the UP9505P is a new IC, could it require firmware programming like some high-end graphics cards such as the RX5700XT?
        What should I do...
        08-02-2025, 11:38 PM
      • harp
        Low voltage very high current rails distribution
        by harp
        Low voltage very high current rail distribution
        I have some mains toroid transformer220v/12v, and thinking to add a few one-two turns fat coil in parallel, like in picture. Red are working windings, purple (top and bottom) is rails who connect all low voltage windings.
        Question is, how to connect that device to be as much more efficient in spot welder operation to distribute and pulls currents to all winding equaly, minimalize voltage drop?
        output on half E-F
        output on C-B
        connect A-B and C-D, output on A-F
        otherwise?...
        10-27-2023, 02:45 PM
