LG EAY62171101 Plasma Power Supply
  • Schoenradt
    • Jan 2021
    • 39
    • US
    Please bear with me I'm new here, But I have had the total run along with LG on trying to get a full schematic and a part number for an LG power supply EAY62171101 out of an LG 50PT350UD Plasma TV. I found at least 7 electrolytic capacitors 20% out of tolerance also the 0.47 UF poly block capacitor measured only .40 UF which was unacceptable. I found on the foil side of the board half of R904 missing. Both pads were still soldered but the ceramic case was cracked in half. I did not see any evidence of overheating or burning. Looks as if it may be a mechanical defect in the manufacturing process.
    This is what my question is. If anyone has one of these versions would it possible to let me know what the value of this smt resistor was R904 ? This appears to be the only issue holding back the power supply from functioning.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
    07-01-2024, 06:34 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
  • CMCM
    Russound CA4 Power Supply Repair
    by CMCM
    Hello Everybody,
    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
    The outputs marked 12v and 20v are all measuring only 1v.
    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
    The capacitors physically look clean (no bludgesor leaks) and...
    07-03-2025, 01:12 PM
