Lg oled65e6p-u.buswljr
  • rplewis
    • Sep 2015
    • 82
    Re: Lg oled65e6p-u.buswljr
    not having any luck with remote on the phone.
    • Diah
      • Feb 2013
      • 6500
      Originally posted by rplewis
      I thought I found a T-Con board but I don't think it will work. All the numbers and letters on the board are right but the TV model number is different. My TV model is OLED65E6P-U.BUSWLJR and the T-Con I found is OLED65G6P-U. With the TV model being different, do you think the T-Con I found would work or should I try to find one with the same model number?
      Man.. i wrote many time yours mobile didn't work because it hadn't IR blaster
      about T-CON you can check this or any same with less price
      it show to me here 32$
      • rplewis
        • Sep 2015
        • 82
        Sorry about that... not the smartest marble in the bag...LOL! I saw that T-Con board. I will order it. Do you think I should order the main board too?
        • Diah
          • Feb 2013
          • 6500
          you need to look at the front led indicator of the lg when you turn it on by pressing power.. did it blinking and then back to stand by?
          • rplewis
            • Sep 2015
            • 82
            Stays on solid with no blinking at all when I press the power button on the TV or remote.
            • Diah
              • Feb 2013
              • 6500
              cant be.. check all sockets on the main boards of the front Led.. you may have one cutting or not in place
              • rplewis
                • Sep 2015
                • 82
                All sockets look to be connected properly. I have no red LED lights working on the main board. When I first started diagnosing, there where LED lights. (I think 2 of them)
                • Diah
                  • Feb 2013
                  • 6500
                  it may the mainboards went to blocking mode..
                  you should success with the following:
                  i posted for you all wav. files at post #60 unzip them and use Power Only wav.. play it on the pc with WinAmp program or VLC .. be sure on the PC the headphone volume full 100% and main volume too
                  take any ear or headphone jack and connect the the end wire of them to IR sender, you can take it out from any remote control you have..
                  ( notice the + & - of the IR ) + to the center of the jack and - to chassis or out pin )
                  let the IR led face the tv and play the wave.. to be sure it send signal you can use your mobile camera focused on the LED IR sender it will blink when you play the wave file... use only Power Only wave all you need at this time.
                  • rplewis
                    • Sep 2015
                    • 82
                    All sockets look to be correct. Nothing appears to be cut or binding. I do remember when I first started diagnosing, that there were lights on the main board ( I think 2 of them). Now there is no lights on the main board.
                    • rplewis
                      • Sep 2015
                      • 82
                      Sorry for the repeat message... the firs wasn't showing up.
                      • rplewis
                        • Sep 2015
                        • 82
                        Never done the remote IR before. I've taken the IR circuit board out of remote. So I need to get a stereo headphone plug with wires attached to the ground of the post and one connected to the center of the post. Where on the IR board do I connect these 2 wires? Would it be the positive and negative battery connects? Also, how long should this wav file play? The one I've got here only last a second.
                        • Diah
                          • Feb 2013
                          • 6500
                          no battery should be at yours RC, the cable connect them direct to the IR sender pins.
                          play wave once. test your work with your mobile camera until you can see the IR blinking once red or more.. then play it to the tv
                          you may need to try all the jack cable until you see with camera the blink of IR
                          • rplewis
                            • Sep 2015
                            • 82
                            struggling to get this remote IR working. The wave file only plays for less than a second. Attached is photo of IR remote.
                            • Diah
                              • Feb 2013
                              • 6500
                              if you use VLC program you can toggle it to play the wav endloss to test the ir with camera.. you use the pins of the diode IR at the bottom side
                              and dont forget to be sure the socket on the pc some had headphone output and microphone input
                              • rplewis
                                • Sep 2015
                                • 82
                                I don't need any power on the IR board? Just having no luck...
                                • Diah
                                  • Feb 2013
                                  • 6500
                                  you dont need the board at all or to power it.. lol , we use only IR sender Diode..
                                  ask friend if any had android with IR blaster to install on it RCoid app or the one i gave you... or you need to buy LG service remote control
                                  • rplewis
                                    • Sep 2015
                                    • 82
                                    I've got a buddy looking to see if he has a phone that we could do IR blaster. I really thank you for all of your help and patients.
                                    • Hink85
                                      • May 2019
                                      • 22
                                      I just went through a 55" LG OLED55C6P-U and it is very similar to your tv. I was measuring 3.5V on the 12VT_ON, and I wasn't sure if that was correct or not, but the t.v. had all the 12, 24, and 3.5 voltages. The T-Con board didn't have any bad fuses and had the 12 and 24 voltages. I ordered a replacement T-Con board (from the same site Diah recommended) thinking that was suspect, but it didn't fix the tv. I then went ahead and ordered the Main board, and the tv has worked since (I did have a section of picture that was blurry). I ended up putting the original T-Con board back in and the picture appeared to be resolved. I'm not up to par on these newer tvs and how protections work, but I do know I had the majority of the voltages coming off the power supply and the screen would occasionally give me a full screen of different colored squares when I attempted to turn the tv on. The main board was the culprit on mine though. I will try to throw up some pics.
                                      • Hink85
                                        • May 2019
                                        • 22
                                        My first attachment was a pixelated screen that I randomly got after disconnecting the main board. That made be believe the screen was fine. I just thought the main board was kicking the screen out. The second and third pic were after I replaced the main board, it had the section of screen that was showing a rounded image in the middle of the screen but you could see vertical lines as well. I put the original T-Con in after I saw that, thinking it wouldn't resolve it, but it did and the final picture was the end result.
                                        I would love to know if anyone could have any explanation on what may have caused that pattern on the middle of the screen. Could it have been a ribbon cable not perfectly seated or possibly a bad T-Con board that I ordered. I was actually planning to write up a separate post for that, if I didn't resolve it.
                                        • Diah
                                          • Feb 2013
                                          • 6500
                                          its issue of firmware version lag between replacement T-CON and the main firmware at the main boards.(the answer downgrade and update the firmware and use In_STOP )
                                          read this threat
                                          and the solution start at post #26
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
                                          • BakaMonogatari
                                            LG 65UJ6300 no backlight unless TCON disconnected.
                                            by BakaMonogatari
                                            Full model of the TV is 65UJ6300-UA.BUSYLOR. TV was given to me by a relative as non-operational so I'm trying to get it working so I have a nice cheap upgrade for my living room. This is my first TV repair so if it sounds a little like I know what I'm talking about, I don't.
                                            TV turns on and has audio, but backlight doesn't turn on. Getting 230v from LED+ to chassis. Also can't see anything with flashlight test. Another forum suggested I replace the LED strips because that's the most common failure on LG TV's and the flashlight test doesn't always show results.
                                            11-04-2021, 12:36 PM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                          • ugamazing
                                            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                            by ugamazing
                                            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                            12-17-2024, 07:05 PM
                                          • maxim2511
                                            LG 55EC930V OLED - swich on swich of no screen
                                            by maxim2511
                                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                            Then I get an idea to take it apart and clean boards from dust.
                                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                            05-14-2021, 02:21 AM
