quick plasma question lg 42 pa 4500
  • jimbofz
    • Apr 2013
    • 539
    • uk
    with the tv unplugged and not in use:
    if a plasma screen has a yellowish patch or tinge
    is this a sign that the panel is gassed
    or worn?
    its hard to photograph
    but in daylight instead of being a uniform black,
    it looks yellowish in the corner ,theres no sign of cabinet damage.
  • jimbofz
    • Apr 2013
    • 539
    • uk
    Re: quick plasma question lg 42 pa 4500
    anybody comment please
    • zen
      • 511
      Bit of a mission , but all i can think of is removing display to clean .
      • R_J
        • Jun 2012
        • 9624
        It does look like this model has a uv filter in front of the plasma panel so either the uv filter or the front of the panel would need to be cleaned.
        • jimbofz
          • Apr 2013
          • 539
          • uk
          i was given this set and its s/c igbts on y sus ,
          before i order parts i just wanted to know if im wasting my time if the display panel is duff thanks,
          as ive never seen this yellowing before .
          in the old days of crts the phosphor used on some crts was greenish
          • R_J
            • Jun 2012
            • 9624
            Where did you get the tv? did the place have people that smoked?
            • jimbofz
              • Apr 2013
              • 539
              • uk
              no tv is clean no smell of cigs,i was told it hadnt been used for a while
              • jimbofz
                • Apr 2013
                • 539
                • uk
                sorted
                for anyone with similar conditions the front reflection diffuser glass was removed and it was clear some of the coating had faded
                i assume when it was not in use it had direct sunlight on it for years
                in no way does it affect pic when in use
                • KYBOSH
                  Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                  by KYBOSH
                  Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                  No picture but you hear the TV static (white noise) playing loud and clear.
                  The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                  But it seems they didn't get too far and just left it.
                  When I first took a look I was amazed at how pristine the inside looked.
                  Its as if the TV had been in a time capsule.
                  Caps looked like they were just pulled off the self.
                  Copper coils had no sign of corrosion on...
                  02-01-2023, 11:10 PM
                • ArMaaN376
                  Samsung PS51E550 Plasma TV
                  by ArMaaN376
                  I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                  Opened TV cover & observed foll
                  a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                  b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                  c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                  How to confirm Y -Buffer board...
                  06-19-2024, 04:05 AM
                • jm1234
                  Panasonic plasma TX-P42ST50 - 6 blinks
                  by jm1234
                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                  I checked that board for any obvious faults...
                  05-22-2024, 06:59 AM
                • alltvrepairs
                  Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                  by alltvrepairs
                  I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                  I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                  Any one met this problem in the past?...
                  10-08-2025, 07:34 AM
                • chazh
                  LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                  by chazh
                  This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                  I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                  The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                  09-01-2025, 08:56 PM
