LG 86ul3e-t logo blinks and then nothing (but backlight stays on)
  • Panczis
    • Oct 2020
    • 28
    • Polska
    Hello
    I'm trying to fix a 86inch monitor from LG. It is LG 86ul3e-t
    The symptoms are:
    - after power on the LG logo blinks for a 1-2 seconds (there is a horizontal line visible for a short while at a top).
    - then the screen comes black, but the backlight stays on
    I can power it off with a remote control.
    I thought that the mainboard was damaged, but I have checked it with another one buyed on auction, and it didn't helped. I have checked also another power board, and even changed all three boards pulled from another 86inch LG TV. Every time the same result - LG logo and black screen.
    LCD panel looks fine. LG Logo looks excelent, when it is shown
    I tried to checked the backlight LEDs, and all LEDs are fine. With the external tester, each LED circtuit shows 216V DC. When I measure the voltage on the power board, then on the first circuit (left side) I get 215-216V, but on the seond one I see valid result 211-214V. But as I said - all LEDs works.
    Does onyone has an idea, what elese may I check?
  • Diah
    • Feb 2013
    • 6365
    Re: LG 86ul3e-t logo blinks and then nothing (but backlight stays on)
    could you show photo on whole back of boards to see how they connected... specially the T-CON. if it separated or integrated with panel.
    BTW. did you feed it with signal before turning it on ???
    • Panczis
      • Oct 2020
      • 28
      • Polska
      The TV is currently dissasembled. I checking the led strips, but all looks fine there for now.
      I'm attaching the pictures, that may show how the circuit boards are connected.
      I tried to connect a laptop VIA HDMI, but nothing was shown on the panel. I can't enter the menu. Only power up/down is possible from the remote.
      The led at the bottom of the TV flash 7 times during the startup. If the TV stays on for a couple of minutes, than it reboot itself (on the orginal mainboard). When I tried to connect the boards pulled from the 86inch TV, than it doesn't reboot, but just stays with the backlight on, without any picture on the screen
      • Diah
        • Feb 2013
        • 6365
        this way you will be in lost.. the best way. are
        1-put all back.. install the original Main Boards in place.
        the test to close diagnose:-
        1- disconnect the wifi module & speaker from the set and turn on. ( to remove load ) if every things as before you have the 7 blinking.. then --->
        2- locate the SPI flash on the T-CON.. write over here its label. ( the horizontal line you showed over here on the right top side.. its much T-CON issue..) but let start with T-CON firmware.
        3- disconnect one side of the panel ( 2 ribbon at once ) from each side.. see if the blinking cleared. and look if the panel display half picture..( this test should be with Signal preferred HDMI signal ) so the set will sync the signal and switched to input automatically.
        • Panczis
          • Oct 2020
          • 28
          • Polska
          Hello
          I have reassembled all parts together again.
          Here is the result, when the two tapes from the TCON to the LCD drivers disconnected. On the next pictures you can see what happens, when the next two tapes are disconnected. I have disconnected also only the third tape, and only the fourth one.
          The logo appears only when all four tapes from TCON to the drivers are in place.
          I've connected my laptop via HDMI, according to your request. You were right - monitor was recognised in Windows as "LG Electronics LG SIGNAGE". But it didn't changed anything with the display, as is still stays black with and the backlight stays on.
          My assumption is, that the the power board works fine, the mainboard too. Backlight was tested, and all looks fine there. So the problem is somewhere in TCON or in the LCD drivers. I suppose that the LCD panel itself works fine, as it shows the beautifill LG logo, when it starts.
          Regarding the TCON
          I'm not sure which number represents the firmware version, which you have asked, so I'm adding the pictures of both TCON boards that I have (orginal one is on the metal background). Both TCONs works the same, so only the LG logo is visible at the start, and then the same problem with no picture on display.
          It looks like a some sort of protection. I have no idea where the problem could be.
          What else should I check?
          • Diah
            • Feb 2013
            • 6365
            okay..
            yours Photo . its look we have no clear white screen on this half.. but this issue we can deal with it later..
            i want you to do the following exactly.
            1- plug AIR MOUSE at any usb port and switch the set on...move the mouse up down left right and press left and right bottom.. we need to see if the set turn out to protection mode because of the panel issue
            2- Ready USB Stick , and copy on it all 3 picture .jpg format after you extract the zip you can use them also beside the air mouse... or if you have movie mpeg format you can add it too.
            tell the result
            • Panczis
              • Oct 2020
              • 28
              • Polska
              I will follow your advices in next two days. I really appreciate all those hints that I got.
              • Panczis
                • Oct 2020
                • 28
                • Polska
                I tried a cable mouse, but unfortunatelly nothing was shown on the screen. The logo appeard like always, then the black screen. The mouse is not visible on the screen. The IR light below the mouse gets red, when the TV is powered on.
                I have prepared the USB stick with those JPG files and some mpeg/mpg movies too. But the screen still stays black (the backlight stays on)
                Should I look for a air (wireless) mouse?
                • Diah
                  • Feb 2013
                  • 6365
                  upload very close high resolution Photos of the panel edge boards from both side left and right.. we need to check if there are circuit build in which it make cutting signal.. between did this panel come with touch function??
                  • Diah
                    • Feb 2013
                    • 6365
                    by the way... you may have the signage Public setting turned off
                    press setting on the remote control for more than 5 seconds. it will display for you password inter 1 1 0 5 then press okay... turn on all setting there...
                    • Panczis
                      • Oct 2020
                      • 28
                      • Polska
                      First the answers to your last questions:
                      - this is a normal display, without touch function
                      - the settings button doesn't work, so nothing was shown on the display
                      Regarding the driver boards, here are the pictures.
                      The horizontal line that flashes on the screen, apperars only, when the right panel ribbons are connected (in fact it apperas only when the third ribbon is connected, as it is shown on the tcon_2.jpg picture). So I think that the problem is in the third driver board. There is also something written with a permanent marker there (pictures driver_3_2.jpg and driver_3_3.jpg).
                      What should I do next?
                      • Diah
                        • Feb 2013
                        • 6365
                        put every things as it should. original and do as i wrote in post #10 the password will show on the top corner left side of the panel
                        • Panczis
                          • Oct 2020
                          • 28
                          • Polska
                          I already wrote, that the settings button doesn't work. I'm pressing it, but the display stays black(with backlight on). I can only turn off/on the TV with a power button from the remote. It seems that the panel is in protection mode or something like this.
                          Could it be a problem if I'm not using the original remote from this monitor? My pilot is from LG TV, but as I said - it can power ON/OFF the device.
                          Some additional data. There are 4 buttons on the motherboard, as on attached pictures. I'm using 2 remotes and a application on my smartphone. All remotes are able to power ON/OFF the TV, but none of them can display anything after clicking the settings menu.
                          I have another set of motherboards from a LG TV, the same type. Maybe I should try with those boards?
                          It looks like a protection mechanism from a LCD panel. Driver sense some error on the 3rd IC board and it sends a power of as a protection mechanism. After the logo appears the screen can't display anything more. Mouse change nothing, USB with jpgs too, and the same with the remote and settings button
                          Some videos
                          Only Left ribbons disconnected
                          https://photos.app.goo.gl/Rn9c3CjYYM8soss29
                          Only Right ribbons disconnected
                          https://photos.app.goo.gl/Q9AeEz9JYTzXneSd9
                          Startup with LG logo:
                          https://photos.app.goo.gl/bFTGsJsoyG1gq4B17
                          • Diah
                            • Feb 2013
                            • 6365
                            both remote wasn't original belong to this Monitor !!! if you have android mobile with IR sender like Galaxy S5 download apk smart remote or RCoid and use them to send INSTOP to reset the eeprom of the set.. when the set On send the command followed with 0413 the set will go to stand by.. if there any protection or wrong setting will be set to default ( factory state )
                            • Diah
                              • Feb 2013
                              • 6365
                              one things more--- maybe this monitor was before connected via P2P ( mean via network ) so plug LAN cable from yours router to it... in case our thought was correct it should wake up and tell you NO SIGNAL
                              • Panczis
                                • Oct 2020
                                • 28
                                • Polska
                                I have followed your advice. With RCoid and a LG service remote I was able to send the INSTOP command, confirmed with the code 0413. TV has set itself to the standby mode. Unfortunatelly, after the power on, the whole story repeats, and there is again only a LG log, a horizontal line flash for a while, and the screen stays black.
                                • Diah
                                  • Feb 2013
                                  • 6365
                                  did it show you the password box when you sent INSTOP ?
                                  • Panczis
                                    • Oct 2020
                                    • 28
                                    • Polska
                                    No. I just pressed in-stop (the remote sensor led on the TV blinked), typed the code on remote (the remote sensor led on the TV blinked) and pressed in-stop again and the TV went to stand by mode. Nothing shows on the TV for all the time. No metter what I'm trying to press there is the same situation all the time. The backlit is on and there is nothing on the screen... You can see it on the movie I attached to the message #13
                                    • Panczis
                                      • Oct 2020
                                      • 28
                                      • Polska
                                      I connected LAN - and the situation is the same again. Backlit on and nothing on the screen...
                                      • Diah
                                        • Feb 2013
                                        • 6365
                                        LOL mysterious..
                                        1- INSTOP need to send one time only.. you send it then follow with 0413 ( nothings more need ) if the set accept it will turn off to stand by alone.
                                        2- you wrote when you pressed INSTOP on the mobile remote the LG LED at front blinked... good if it so... did it blinked before when you tried press setting on the remote to inter the menu ???
                                        • events.b
                                          Sceptre X505BV - Logo appears for 1 sec then backlight shuts off, LEDs tested good
                                          by events.b
                                          Hello, this TV currently has me stumped. As the title states, when I power on the unit, the backlight comes on for 1 second then shuts off. The TV is still on, and I can see the video if I shine a flashlight on the screen.
                                          Using the LED backlight tester I was able to confirm all LEDs are illuminating and seem to be working correctly when independently powered by this tester, so that leads me to believe there is something wrong with the power supply board.
                                          Perhaps the great minds here can help me figure it out, as I don't see any thing obviously wrong with it. The...
                                          02-08-2021, 11:03 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
                                        • hollox123
                                          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                          by hollox123
                                          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                          1. Laptop keyboard doesn't work
                                          2. The backlight on the laptop keyboard doesn't work
                                          3. The x2 side LEDs (red) on the laptop don't work
                                          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                          But I am strongly aiming that it is somehow a BIOS-related problem,...
                                          05-11-2025, 08:05 AM
                                        • signal.quest
                                          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                          by signal.quest
                                          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                          03-17-2024, 10:14 AM
