SONY KDL 43w805c does not accept commands
  • Diah
    replied
    Re: SONY KDL 43w805c does not accept commands
    which heat equipment do you have ? show me to let the work being perfect this area i mean
  • Dobsuk
    replied
    Originally posted by Diah View Post
    ok then heat this chip with hot air gun specially the middle to left side facing the plug which goes to side panel
    when you heat it try dont move the boards ...leave it cool then put it back
    For how long i need to heat it?
  • Dobsuk
    replied
    I did in #27
  • Diah
    replied
  • Dobsuk
    replied
    one things more before we go for heating... your photo https://www.badcaps.net/forum/attach...5&d=1610728654
    the side panel and led indicator IR receiver socket... are they connected with ribbon flat cable to the middle of the mainboards?? if yes... did you inspect under loop the end silver pins of the cable if any short or broken ???? yours issue very strange
    No, they are not with ribbon cables:
  • Dobsuk
    replied
    take out the heat sink... it need heating to repair the BGA ... by removing the heat sink we can tell from which side (PIN ) on ship are responsible
    This is it:
  • Diah
    replied
  • Diah
    replied
  • Dobsuk
    replied
    by the way... when it start at select language did you hear the music ? if yes you increase the volume or decrease from side panel... is there response and did you have notification bar ?
    Yeah, i can hear the music and the volume responds but cannot see notification bar every time. But he volume is working - i can turn it up or down even i can or not see the notification volume bar.
  • Diah
    replied
  • Diah
    replied
    Originally posted by Dobsuk View Post
    Yeah, i found the same but it looks it does not work. And can see the comments under the post, seems nobody has success with that rollback
    I tried and using your advice, Diah
    It looks i need to looking to buy Main board
    no need to buy new mainboards...
    take out the heat sink of the CPU and show what we have under it
  • Dobsuk
    replied
    inset it in USB Port Ver 2. and do the procedure as you doing hard reset. you need to release the power & Volume - only when you see the usb led indicator start blinking
  • Dobsuk
    replied
    just to be sure you did hard reset correct..
    1-while the set on plug it out from wall socket
    2- plug out any cable / antena etc from the set ( keep it solo )
    3- press on the tv side panel volume - & power and keep press then plug it in wall ac again.. the front LED will change to green... after it change to green release the keys you pressed before.
    4- leave the set it will reset and it will show you first install but it will reset again and reboot..--- this mean after the set rebooted 2 time and the first install remain on screen the set finished reset.
    you must use air mouse. because its plug & play with android
    Yeah, mate! I did that few times. I can see the green led light and you can see that my TV is coming in the first Welcome screen after hard reset.
  • Diah
    replied
    Thank you! I am going to try some of them now....
    there is procedure of rollback 2015 set firmware listed at Sony UK ,,you can download the pkg.
  • Dobsuk
    replied
    there are 2 kind of regions android 5 for Sony 2015 as yours w805c so i listed for you very early version for eua ...
    and this eua sony_tvupdate_2015_2637_eua_auth.zip
  • Diah
    replied
  • Dobsuk
    replied
    did you use air mouse??
    Errm, no mate. I did not get you that you are talking about air mouse. Sorry. I do not have air mouse.
  • Diah
    replied
    YEah it is working but for few seconds only... then it is freezing for few secs and so on.
    Found some procedure for downgrade on Internet but cannot find older firmware for my TV.
    Thank you, Diah!
  • Dobsuk
    replied
    f you did hard reset as press power and Volume - then plug set in AC and it show for you erase on screen .. then Air mouse will work.
    put the last update firmware on USB stick not larger than 4GB formatted FAT 32... inset it in USB Port Ver 2. and do the procedure as you doing hard reset. you need to release the power & Volume - only when you see the usb led indicator start blinking. do it many time until you succeed.
    Did that about 10 times but nothing - it is just looping in the boot logo and turn off again and on and off ..... May be it is not possible to reflash it with the same firmware version. Found some procedure for downgrade on Internet but cannot find older firmware for my TV.
    if this not help need to open the cover and show me the main boards to see which version its.
    Thank you, Diah!
  • Diah
    replied
    Yeah, but the point is it stuck on the welcome screen. So, i cannot use any APK to control it via the network until the tv is not connected to the network. And my problem is not that this volume graphic is missing... The problem is that it does not accept command neither from the remote control nor from the side control panel.
    Just tried with the mouse now and nothing - i can see the mouse coursor and move it for 2-3 sec and then it is freezing for few sec and so on.... Is there how to reflash the TV with USB stick even it is with the latest firmware already?
    put the last update firmware on USB stick not larger than 4GB formatted FAT 32... inset it in USB Port Ver 2. and do the procedure as you doing hard reset. you need to release the power & Volume - only when you see the usb led indicator start blinking. do it many time until you succeed. if this not help need to open the cover and show me the main boards to see which version its.
