Re: SONY KDL 43w805c does not accept commands
which heat equipment do you have ? show me to let the work being perfect this area i mean
Originally posted by Diah View Postok then heat this chip with hot air gun specially the middle to left side facing the plug which goes to side panel
when you heat it try dont move the boards ...leave it cool then put it back
when you heat it try dont move the boards ...leave it cool then put it backLast edited by Diah; 01-15-2021, 02:40 PM.
Originally posted by Diah View Postone things more before we go for heating... your photo https://www.badcaps.net/forum/attach...5&d=1610728654
the side panel and led indicator IR receiver socket... are they connected with ribbon flat cable to the middle of the mainboards?? if yes... did you inspect under loop the end silver pins of the cable if any short or broken ???? yours issue very strange
take out the heat sink... it need heating to repair the BGA ... by removing the heat sink we can tell from which side (PIN ) on ship are responsible
Originally posted by Diah View Postby the way... when it start at select language did you hear the music ? if yes you increase the volume or decrease from side panel... is there response and did you have notification bar ?
Originally posted by Dobsuk View PostYeah, i found the same but it looks it does not work. And can see the comments under the post, seems nobody has success with that rollback
I tried and using your advice, Diah
It looks i need to looking to buy Main board
take out the heat sink of the CPU and show what we have under it
inset it in USB Port Ver 2. and do the procedure as you doing hard reset. you need to release the power & Volume - only when you see the usb led indicator start blinking
Originally posted by Diah View Postjust to be sure you did hard reset correct..
1-while the set on plug it out from wall socket
2- plug out any cable / antena etc from the set ( keep it solo )
3- press on the tv side panel volume - & power and keep press then plug it in wall ac again.. the front LED will change to green... after it change to green release the keys you pressed before.
4- leave the set it will reset and it will show you first install but it will reset again and reboot..--- this mean after the set rebooted 2 time and the first install remain on screen the set finished reset.
you must use air mouse. because its plug & play with android
Originally posted by Dobsuk View PostThank you! I am going to try some of them now....
Originally posted by Diah View Postthere are 2 kind of regions android 5 for Sony 2015 as yours w805c so i listed for you very early version for eua ...
and this eua sony_tvupdate_2015_2637_eua_auth.zip
you must use air mouse. because its plug & play with androidLast edited by Diah; 01-15-2021, 11:42 AM.
Originally posted by Dobsuk View PostYEah it is working but for few seconds only... then it is freezing for few secs and so on.
Originally posted by Dobsuk View PostFound some procedure for downgrade on Internet but cannot find older firmware for my TV.
Thank you, Diah!
and this eua sony_tvupdate_2015_2637_eua_auth.zipLast edited by Diah; 01-15-2021, 11:30 AM.
Originally posted by Diah View Postf you did hard reset as press power and Volume - then plug set in AC and it show for you erase on screen .. then Air mouse will work.
put the last update firmware on USB stick not larger than 4GB formatted FAT 32... inset it in USB Port Ver 2. and do the procedure as you doing hard reset. you need to release the power & Volume - only when you see the usb led indicator start blinking. do it many time until you succeed.
if this not help need to open the cover and show me the main boards to see which version its.
Thank you, Diah!Last edited by Dobsuk; 01-15-2021, 10:42 AM.
Originally posted by Dobsuk View PostYeah, but the point is it stuck on the welcome screen. So, i cannot use any APK to control it via the network until the tv is not connected to the network. And my problem is not that this volume graphic is missing... The problem is that it does not accept command neither from the remote control nor from the side control panel.
Just tried with the mouse now and nothing - i can see the mouse coursor and move it for 2-3 sec and then it is freezing for few sec and so on.... Is there how to reflash the TV with USB stick even it is with the latest firmware already?
put the last update firmware on USB stick not larger than 4GB formatted FAT 32... inset it in USB Port Ver 2. and do the procedure as you doing hard reset. you need to release the power & Volume - only when you see the usb led indicator start blinking. do it many time until you succeed. if this not help need to open the cover and show me the main boards to see which version its.Last edited by Diah; 01-15-2021, 09:44 AM.
