Sony XBR-55A9G & Sony XBR-55A8G
  • andrewftw
    • Dec 2020
    • 8
    • U.S.
    Firstly, I am very new to this site so please don't get angry with me and call me names (n00b, idiot, etc.) if I accidentally post this in the wrong thread, or should post elsewhere. Just kindly redirect me.
    I am posting for two separate reasons, although one and the same. I am repairing and replacing parts for the two Sony OLED models I listed.
    Firstly, I have managed to find a majority of the parts necessary except I am missing an infrared sensor on the Sony XBR-55A9G. It is difficult to find by just naming it that. I have scoured the internet for service repair manuals and even called a few local shops in hopes they would be kind enough to lend a hand by sharing a manual I was unsuccessful (obviously why I am here). This leads me to the second reason I am posting as I have spent countless hours searching the internet to no avail trying to find schematics, manuals, or PCBs for these specific models. While I have come across X900 and such models, none for the A9G, A8G, A8F, etc.
    As I stated earlier I am extremely new to this site and do not know how many OLED service/repair tech's are active on this site. I own a business dealing with electronics and components and do some cybersecurity consulting on the side. Although because I am new I am not a Sony Authorizeed Service Center or an LG Authorized Service Center but I am working on it in the meantime.
    If this is the wrong thread, please kindly post where I ought to post my inquiry.
    Best,
    Andrew Millsap
  • Diah
    • Feb 2013
    • 6438
    Re: Sony XBR-55A9G & Sony XBR-55A8G
    first welcome here.. let start with one model you have and explain what are the fault you are facing and always please "GO Advanced" to upload focused high resolutions picture on whole back to see how boards connected to each other..and photos of the power boards complete and the sockets label which going to main boards and to T-CON driver boards.
    in General as you know OLED TVs are all include LG panel and LG T-con driver boards.. and i can help you with this.
    • andrewftw
      • Dec 2020
      • 8
      • U.S.
      Diah,
      Thank you dearly. Yes I am aware of LG's relationship with OLED and have been in contact with LG Display multiple times. I have no problem sending pictures but I was just needing advice on where to find an IR Sensor/connector to the back panel for the 55A9G. I have replaced the TCON board and mainboard, all I need a single ribbon cable for the four at the bottom of the TCON board as it is missing one, as well as the IR Sensor/Board.
      I was hoping to find schematics or a manual of that nature to be able to find the part numbers for what I am looking for. Are you aware of any place I can find one?
      If you would still like me to post photos, let me know.
      Best,
      Andrew Millsap
      • Diah
        • Feb 2013
        • 6438
        Originally posted by andrewftw
        Diah,
        Andrew Millsap
        are you in DIY project to build SONY OLED ?
        what kind of Ribbon. pins NO. & the align Order. some model have the first 2 pins line and the last 2 pins line wide shape, show here one of yours ribbon. !
        from the socket of the IR on the main boards you need to check the pins specially if there TX & RX as its no only IR receiver but also Bluetooth one.
        if it was just IR ( i dont think so ) its easily to DIY it with another SONY brand.
        if its with Bluetooth you can find many from XBR series native LINUX or / android too
        • andrewftw
          • Dec 2020
          • 8
          • U.S.
          I have attached the photos to a .pdf file one shows me holding the cable connector for the port (IR Sensor I assume it goes to) the other photos show the missing TCON ribbon cable I am trying to find. Any help would be greatly appreciated. Thank you for reaching out as quickly as you did.
          • Diah
            • Feb 2013
            • 6438
            i am confused .. one shows you !!!!!
            i can see only some one hold socket in his hand and this belong to the boards which screwed on the top of T-CON metal shield
            nothings more.. and please post pure jpg photo. no need to convert them to pdf
            • brucetv
              • May 2015
              • 281
              • united states
              Try www.encompassparts.com and put in the model number in the search window and hit enter. This will pull up most of the parts for your model. Sony usually has the part number on the ribbon cable but if you don't have it you may have to call them so they can look at their schematic to get the right one. Good luck
              • andrewftw
                • Dec 2020
                • 8
                • U.S.
                I found schematics, repair manuals, and large blown-up images for every new model of Sony OLED's. Master series, everything. I lucked out and got information only available to Sony Authorized Servicer Repair Centers. There are very few and I happened to get lucky.
                • brucetv
                  • May 2015
                  • 281
                  • united states
                  If you have the schematics and repair manual let's see a copy. It will help us to help you better. Did you see the part number in either manual for the ribbon cable your looking for? Just google that part number and see what you come up with. Try Encompass too. They are usually my go to for hard to find Sony parts.
                  • charlie555
                    • Feb 2018
                    • 76
                    • usa
                    may I have the materials for XBR55A9G?
                    • andrewftw
                      • Dec 2020
                      • 8
                      • U.S.
                      Update: Private message me for more information.
                      @brucetv i would love to discuss further with you offline. The part numbers are strange and encompass seems to have been out of stock for the individual ribbon cable i was looking for.
                      I am not sure how the part numbers in the schematics refer to the part numbers on encompass and other places, they often don't match and are differently lettered/numbered. I have been racking my brain as to how to find a specific part that has the number on the schematic/service manual but can't seem to find anything with the same alphanumerics online.
                      I really
                      • alfatv
                        • Sep 2020
                        • 353
                        If it was me, I would just wire up IR sensor from another TV. They all have similar operating principle.
                        Another option is to find TV with broken screen.
                        Also see on eBay who is selling parts for this model and ask.
                        • andrewftw
                          • Dec 2020
                          • 8
                          • U.S.
                          Hello all,
                          Sorry for my delayed response, I plan to become more active within the community threads moving forward. I have an account with Encompass and have for a few years. I have a great relationship with them and they have helped me greatly with parts and such. I do frequently set up search alerts on eBay and have been buying/selling since the early days of ebay. Over 10+ years. The issue I was having is wondering A) whether or not a 41-Pin/51-Pin Flexible Flat Cable (41-P) and (51-P) that connects the TCon Board to the OLED Panel was interchangeable between 55"/65" and 77" A9G's or A8G's respectively. I know most parts, if not all parts, are interchangeable between 55" & 65" OLEDs (of the same model of course) but more so was wondering whether or not those same 41-Pin/51-Pin ribbon cables were interchangeable with the 77" as well.
                          The schematics all show different numbers for the cables on each separate size 55", 65" and 77". Although, I know T-Con Boards can be replaced by one of like three or four variations of the same Board. I think It's like 5871-A, 5871-C and maybe 5871-D or -P. I can't remember the T-Con model #'s exactly off the top of my head, I was merely, using that as an analogy to help explain my question regarding the T-Con ribbon Cables that connect to the Sony OLED Panel.
                          Any help is welcomed. Not asking anyone to do "my work for me." Just looking to chat and pick brains.
                          If anyone would like to add me as a connection or private message feel free to.
                          Best,
                          Andrew
                          • njsutton1995@outlook.com
                            • Jan 2021
                            • 8
                            • united states
                            Has anyone had any luck getting the firmware to take on this model?
                            I know my TV is good, I have successfully update firmware on one main board, but this tv is a tester in my shop and I can not get tv to update on a board that I'm testing. It has power, light from my optical audio out, soft white indicator light but no update.
                            • swifttech00
                              • May 2021
                              • US
                              Hi, I'm new to this community and have been trying to get some info on 65A9G which has 4 blink code and if i disconnect Tcon board, main board seems to stay on( could see optical out stays on). Looking for directions to see what i can do find where the problem is ?
                              • swifttech00
                                • May 2021
                                • US
                                starts with white light and in few seconds starts blinking 4 times(turns red) once I power it on. no picture and no backlight..
                                so far I understood it is panel or LD board problem. Is this correct for A9G?
                                I disconnected LVDS cables to the Tcon(from main board) and could see the TV stays ON( white light stays ON and could see optical light stays ON on the main board). - does this mean mainboard ok ?
                                started testing by disconnecting the 4 cables one by one from tcon to the lcd panels and 4 blinking light continues but when i disconnect the right side last connector, it starts to blink 5 times instead of 4. - does this mean is this where the error code is being generated ? or tcon board faulty as well ?
                                when trying to mask(put a tape on the cable) clk signals from the last cable( this is where clk signals are mentioned on the tcon board, i still get the 4 blink except if i block last few pins, i get 5 blink error - does this mean left side screen led has problem ?
                                anyone has voltage map for the tcon board(le650aqp-ama2-y31) or service manual or where i can find one ?
                                any instructions on how to remove the LED panel.. there seems to be screw from the back side to hold the ld board in the front. but no way to see the LD board connecting to tcon board.
                                bl_err cable receives 3.5v after powering on and then i see the 4 blink light(red) so the grounding the bl_err doesnt work for this OLED TV.
                                ref: same tcon as seen in here..https://www.youtube.com/watch?v=WHjJpT77jpY but dosnt seem to be the same problem.
                                • Benjamoreno
                                  • Mar 2023
                                  This is for Andrew. I have the ir board and ribbons you need. My contact email benjamorenos@hotmail.com
                                  • YasaCh
                                    Help me my brothers find a dump for SONY KDL-55W805B TV
                                    by YasaCh
                                    Peace be upon you.
                                    Brothers, I need a dump for a Sony LCD smart TV.
                                    Screen type and model: SONY KDL-55W805B.
                                    Please provide a dump for the device.
                                    The device boots up but the SONY logo doesn't appear at first and remains in this state.
                                    04-17-2025, 11:16 AM
                                    ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                    This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                    09-07-2024, 04:30 AM
                                  • Glaval
                                    Sony OLED XBR-65A8G 4 flashes
                                    by Glaval
                                    Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
                                    01-23-2025, 04:04 PM
                                    Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                    This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-07-2024, 07:12 AM
                                    Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                    This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
