Neo(vestel) 40730 blank blue screen
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    So, my friend asked me about this tv. After some time just stopped working. I opened it checked connectors, power supply - caps and semiconductors.
    For about 2 times there was a picture with the menu on the screen for a second, but mostly blank screen no matter what buttons you press on the remote or the multufunction button on the tv. Its strage, like software problem. After turning on the screen is blue, the edges flash white for a second and then blank. The only thing you can do is to turn it on and off via the remote or multi button. These are PCB-s main and psu. Vestel
    Mb - 7mb97, psu - 17ips12
    Its "smart" tv. With ethernet and youtube.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    Re: Neo(vestel) 40730 blank blue screen
    I was suspecting either firmware problem or bad display. It is bad display. When I bent the front bezel, I saw picture on half of the screen. He also forgot to mention that the TV was dropped from half a meter and there were lines on the right end of the screen. So it is LCD panel damage.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • Chrissygizmo
      Panasonic TX-48CX350B backlights but white screen , blank screen
      by Chrissygizmo
      Hi all, I’ve got a problem I hope someone can help me fixi.
      I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
      01-11-2025, 03:18 PM
    • kotel studios
      Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
      by kotel studios
      Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
      State I got it in:
      Squealing from the PSU
      After logo I get a blank screen
      After 10 seconds of having a blank display w/ backlight the TV dies
      Give it 7-10ish seconds again and it starts to bootloop.
      What I did so far:
      Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
      Checked all voltage rails:
      5VSB - 4.8V
      AMP+13V - 14.4V
      13V - 12.98V (in manual 12V)...
      09-21-2025, 02:00 AM
    • dicky96
      HP Elitebook Screen blank - backlights but no image
      by dicky96
      Hi guys
      I'm trying to fix this laptop screen
      Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
      OK so I have the original screen which works but has lines across the bottom quarter of the screen
      I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
      04-28-2021, 07:30 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
