Haier LT32C360
Haier LT32C360
by Jneub007Hi! Hope you can lend me some advice.
I am attempting to repair a Haier HVTB18DABB thermoelectric wine fridge. Both fans work, but the temps are not changing in the dual zones. Upon inspection, I believe this cap (pictured) and possibly another may be the culprits - based on the base of the caps and what looks to be dried dark liquid at the base. Assuming that is abnormal?
Do you agree and which product do you suggest replacing with?
Very much appreciated! Let me know if more info needed.
Channel: General Capacitor Questions & Issues
by gurangaxI have been trying to revive a dead laptop without sucess. Checked all the voltages and they are present, only bios is left. I have tried to correct this firmware without sucess and seeking for help here.
Attached here is the bios dump.
Laptop model is Haier S2.
S/N: JM032E00004WK3W0451
Board: X133G rev 3.1...-
Channel: BIOS Requests ONLY!
by NicktronicHey Everyone,
I have this Haier 43" TV Power Board that is not supplying enough voltage to turn on the LED Backlights. When the TV is powered on, I get about 60 VDC at the connector for the backlights (CON3F) and this is regardless of the backlights being connected or not. I've tested the backlights with a tester and they all work (about 120 VDC for full illumination). So it appears I'm getting half the supply voltage. I've changed out the 22uF 200V cap (C25F) with a 22uF 450V that I had kicking around. No change and the original cap tests good and discharges normally. ... - Loading...
