60PA5500 TV Shutdown
  • Plurxtc1
    • Oct 2014
    • 136
    TV is shutting down. Power supply peaks at VS and VA voltage then drops. Could I be having an issue with the power supply? I already unplugged the Y-Sus and Z-Sus.
    I did not see any of the 3-Pin transistors shorted that were attached to the heatsinks.
    Power Supply is EAY62609801
    Main is EBT62146301
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4316
    • Italy - Milan
    Re: 60PA5500 TV Shutdown
    You have to provide a set of power resistors to load psu outputs then test the voltages. Tell me the output tensions..
    • Biruslapio
      • Nov 2013
      • 552
      • Brasil
      If you disconnect the main board from the PSU it should automatically power on and stay like that while plugged in mains AC, all voltages (VS,VA etc) must be present.
      • Plurxtc1
        • Oct 2014
        • 136
        It's a plasma TV
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Have a read through this thread which may help.
          https://www.badcaps.net/forum/showthread.php?t=38197
          • Biruslapio
            • Nov 2013
            • 552
            • Brasil
            Originally posted by Plurxtc1
            It's a plasma TV
            Whaat? Really it's a plasma? I may have said that because I have the same TV with same power supply as yours and if you only plug in AC it auto starts like every LG plasma. If you do that and have all the voltages stable then it's much more likely the main board shutting down. You only mentioned unplugging Y-SUS and Z-SUS, not mainboard.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              03-31-2024, 02:12 PM
              07-01-2024, 06:34 AM
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
            • CMCM
              Russound CA4 Power Supply Repair
              by CMCM
              Hello Everybody,
              Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
              Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
              The outputs marked 12v and 20v are all measuring only 1v.
              The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
              The capacitors physically look clean (no bludgesor leaks) and...
              07-03-2025, 01:12 PM
