Samsung UN46C6300SFXZA weird startup
  • BobMaine
    • Nov 2020
    When starting the TV I first get some faint horizontal lines that disappear then some random vertical lines on black screen, then the TV starts up and a gray "film" covers the screen followed by some fixed "ghosting" (fixed faint image that shows up for about a second or two.) Finally this all goes away and I get a clear picture on the screen. Whole process takes about five minutes.
    Occasionally the horizontal lines return.
    Seems like it needs to warm up or something.
    I'm thinking the screen is the culprit but what do I know?
    09-07-2024, 05:50 AM
  • Mohammed Mecegguem
    samsung ue46c6000 weird alternating lines
    by Mohammed Mecegguem
    I encountered an issue with my TV long before noticing a pattern of alternating red lines. Initially, I replaced the T-Con board, but the problem persisted. After a year, I decided to open the TV again and found some oil leaks around the CPU, RAMs, and LVDS FPC connector, likely from the thermal pads. I reconnected the LVDS connector but still faced the same issue with the alternating lines.
    At first, I thought the LVDS cable might be loose. I inspected the cable, found no damage, cleaned the connector, and reconnected it, but the issue remained. This led me to...
    06-19-2024, 01:37 PM
  • Falki
    Colorful LCD Vertical Lines on Samsung ue55es8090
    by Falki
    Hello there, ive recently found an older 55inch Samsung SmartTV.
    Sadly it has vertical lines at the left and one line in the middle-right.
    I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
    I have factory resetted the TV as well but also with no luck.
    I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
    A similar issue has been posted as well but also with no actual response ...
    08-12-2025, 04:19 AM
  • Rubenlily
    Samsung QE50Q67TAU - horizontal lines
    by Rubenlily
    First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
    I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
    I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
    I'm no expert but I've done the tape...
    08-16-2023, 01:12 PM
  • estabilito
    Acer Nitro AN515-55 weird behaviour on startup
    by estabilito
    Hi, I've just repaired acer nitro an515-55 with specs:
    i7-10750h, rtx2060.
    Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
    After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
    i've tried different bios, different vbios and same behaviour - clean windows install too.
    Do you have any idea?
    08-13-2025, 02:52 PM
