Panasonic TC-L47E50
  • dls1972
    • Sep 2020
    • 7
    Panasonic TC-L47E50
    This 47 " Flat screen is working, but when you look closely at the display you can see thin black horizontal lines about every 1/4 inch from top to bottom.
    I replaced the T-CON board but it was not the problem.
    Has anyone seem this problem?
    Thanks. Dan
  • rstrube
    ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
    by rstrube
    Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
    Hi Everyone,
    I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
    Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
    Today, 01:37 PM
  • rstrube
    by rstrube
    Hi Everyone,
    Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
    Today, 12:19 PM
  • BigPete
    Panasonic Heatpump Dryer Repair
    by BigPete
    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
    Unfortunately the whole machine has to come apart to fix it.
    I have...
    11-01-2025, 06:40 PM
  • Andre Gilbert
    by Andre Gilbert
    11-20-2024, 08:52 PM
  • AquaMan Ua
    Problem with PANASONIC CF53 laptop after changing BIOS settings
    by AquaMan Ua
    Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
    05-17-2025, 09:40 AM
