Hisense 2020 ULED 55U8QF Little Factory Fault end with Big damage !!
  • Diah
    • Feb 2013
    • 6362
    this set delivered today to my home to inspect and write report to company sold this set 2 weeks before and the customer reject it as it had fault at picture. its look the transport damage happened during the customer sending it back to the company or on the way to me.. who care its not may fault. LOL
    this ULED had full array LED backlight. from first look after remove the back cover with dozens of screws as 2 part cover. i found the ribbon cable at the panel side they was not correct fitting in place ( see photos before take the T-CON driver boards & After.) my wounder which company in this world can pass QC for product at this condition.. and the worker who did it never notice that..!!??? any way the set made in (assembly) in Czech republic.
    technical test: i did several test to this set to discover any further issue could face users and which sign of defect or errors sign.
    Believe me this set had no any protection circuit in HW & SW at all...
    A- if disconnected the 12V line from PSU to LED driver... the set remain on with sound and picture can be seen by torch.
    B- if disconnected the UART ( yes its UART signal ) between main boards and led driver boards .... the set remain ON as above.
    C- If this UART signal disconnected and just 12V line from PSU to LED driver boards.. all back light lit on in high mode. set remain ON as above.
    D- if you remove one ribbon at time between T_CON & panel you will have half screen normal picture.( there is signal feed ) also if you remove both at once the set remain on with sound only.
    E- if you diconnect the 1 or both LVDS between Main boards and T-CON the set remain ON sound Only..
    tell the truth i never saw such TV even from hisense like this one.. its look to me good for DIY. hope this info could help any one in the future.
    • 12144
    • U.S.
    Re: Hisense 2020 ULED 55U8QF Little Factory Fault end with Big damage !!
    Almost bought a Hisense for 10 bucks the other day, glad I skipped it, looks like poor QC.
    • Diah
      • Feb 2013
      • 6362
      i got permit to keep this QLED set.. first things i will do to exam the QLED cells on the panel ... never had before in practice. LOL
      by the way QLED and Full Array BL are real sucker for house electricity could be same to OLED
        • 12144
        • U.S.
        Uh oh, guess that means you can't trust none of the new technology, the OLED's and NanoCell's definitely are problematic and the QLED's are energy hogs.
        • Diah
          • Feb 2013
          • 6362
          its not only about TRUST. but i will not fill down with companies trick ( just found new Name of Tech or method ). OLED are different. but any others are same.. they are LCD. but they try to increase contrast & Black level.. and here are the trick by full array BL. or some call it local dimming. and other say ULED... other DLED. and other QLED.. and any new name they add the price jump higher..
            • 12144
            • U.S.
            Yep, marketing bs, it's still just a turd on a paper plate.
            • Diah
              • Feb 2013
              • 6362
              Any one saw in his TV carrier TV Panel 55 size installed on the set with 3mm double side glue type which used at Mobile screen ?? and the edge of the LCD are on the top of the front. any kids with his nail can take the panel from its place.
              more test was the LEDs if the currents ( settings backlight ) dropping it down... the LEDs lids on blue color ??
              264 LEDs divided to 5 channel, 4 channels to each corner, the fifth one for the middle only, lighting on alone only when the set start and VIDAA logo was in place.
              i did contact Hisense support with phone.. as usual Hisense call center are the best over all brands, explained to them this found. followed with email answer on their mails with all photos and most understandable information.. and waiting on their replay and reaction.
              by the way the Panel had no any side COFs, just at the button edge one.
              but the story of the Glue with type make me laugh allot.
              • alfatv
                • Sep 2020
                • 353
                A TV expert should know that QLED is using blue LED backlight.
                Yes, LCD is the same, but backlight is totally different.
                BTW, did you find QLED cells?
                • Diah
                  • Feb 2013
                  • 6362
                  sorry man this is wrong statement.. they are going blue only at low current. at high / middle / level current they lighting cool white as usual.
                  this one of reason you cant find at Menu - Setting- picture- Backlight level where you increase or decrease from 0-100. they just replace it with auto-low-middle-high over all these valiable in menu the current are high so they remain white.
                  Quantum dots are video processing design Chips on main boards to control Panel +T-CON signal. this part of signal drive the LED driver to let specific angel on LED lids higher than other. thought Philips used this similar method to RGB ambilight.
                  • alfatv
                    • Sep 2020
                    • 353
                    It could be that Hisense is cheating and using mix of normal white LED light and blue light that is converted to red and green. Or just conversion is not linear at all LED brightness levels. I wouldn't be surprised if they use some sort of inferior solution to lower the cost.
                    Here is some info about quantum dots and QLED:
                    https://en.wikipedia.org/wiki/Quantum_dot_display
                    https://www.digitaltrends.com/home-t...ed-vs-oled-tv/
                    Please share a link supporting this statement.
                    • Diah
                      • Feb 2013
                      • 6362
                      sure 100% cheating. so how they Glue the panel with double side type and panel have very dirty image at dark.
                      no need to link here .. i am talking over here on practice had underhand . if you like search after HI-View Engine powered by Hisense
                      • RRice25541
                        Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
                        by RRice25541
                        So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
                        the color is all outa wack, like the settings have been corupted,
                        I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
                        so
                        The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
                        when i bring up the menu and type the pass codes to access either mode the menu disappears...
                        05-13-2022, 10:44 PM
                      • Rictech
                        Panasonic SA-MAX770PU SMPSU board fault....
                        by Rictech
                        Hello everyone. 😀
                        As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                        Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                        Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                        This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                        There are no devices that have exploded or otherwise show signs...
                        08-26-2024, 01:05 AM
                      • howardc64
                        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                        by howardc64
                        • Prior owner tried a replacement main board. No difference.
                        • Samsung 2x red blinking standby LED = panel fault
                        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                        07-19-2025, 10:54 PM
                      • AK_777
                        Sony KD-65A1 Repair – 4 Red Blinks Error
                        by AK_777
                        Hi everyone!
                        I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                        Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                        02-20-2025, 04:15 PM
                      • ShahZaib Ghumman
                        Can I Swap Screens Between Two Hisense 75” QLED TVs?
                        by ShahZaib Ghumman
                        Hey folks,
                        I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                        A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                        So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                        03-25-2025, 10:59 PM
