pn64e550d1fxzc power issue
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: pn64e550d1fxzc power issue
    Each capacitor has one leg soldered on the top of the board as well as all on the bottom.
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Flood the pad with fresh solder and use desolder braid to remove the fresh solder. Fresh solder tends to be easier to remove.
      • pansatdishman
        • Jun 2013
        • 110
        got it changed still wont power on does the top need to be soldered to as i only soldered the bottom thanks
        • pansatdishman
          • Jun 2013
          • 110
          tv use to work then would tutn off and wouldnt power back on for a while . i took apart and touched up solder joints then no power at all. then changed those caps on the y sustain and tried last night no standby i checked fuses on power supply and there good
          • pansatdishman
            • Jun 2013
            • 110
            i just put solder on the top side of the caps as well and touched up the solder joints on the power supply powered on after a few times of hitting the button then died and wint do anything green light was blinking on control board and everything stopped when it went out
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              #26
              Try running the test patterns.
              • pansatdishman
                • Jun 2013
                • 110
                How do I do that? and currently i cant get the red light or it to turn on or the green light on the control board
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  #28
                  On that model, you disconnect the cable from the power supply and put a wire in the ps on and the other end to the ground. Then on the mainboard, put a wire in holes 3 and 4. Then plug in the tv.
                  • pansatdishman
                    • Jun 2013
                    • 110
                    which one the plug going from the power supply to the mainboard? thanks
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      #30
                      The instructions given by tvjimmy are shown in the attached pdf in post #2
                      • pansatdishman
                        • Jun 2013
                        • 110
                        okay i have the mainboard to ps supply mainboard connector unplugged and connected to pins 1 and 3 tried plugging tv in and nothing happened. i have to short 3 and 4 on the mainboard? where is 3 and 4 or i add another wire to the same connector on 3 and 4 thanks
                        • pansatdishman
                          • Jun 2013
                          • 110
                          tried this and still cant get test patterns. do i have the clip in the right spot on the logic board as mines a bit different then the pic in the pdf thanks
                          • tvtimmy
                            • Mar 2015
                            • 1160
                            • usa
                            #33
                            These are the holes. I hope you didnt do any damage to that chip.
                            The top 2 holes should be #3&4.
                            • pansatdishman
                              • Jun 2013
                              • 110
                              thanks tried it and still nothing. so that means i have a power supply issue? thanks doesnt try to power on no noise or anything
                              • pansatdishman
                                • Jun 2013
                                • 110
                                That's how I had it.
                                • tvtimmy
                                  • Mar 2015
                                  • 1160
                                  • usa
                                  #36
                                  The number of the holes is:
                                  3 4
                                  1 2
                                  Put the jumper in the two top holes.
                                  • pansatdishman
                                    • Jun 2013
                                    • 110
                                    Thanks I used a bread tie for holes 3 and 4 and plugged the tv in and it still doesn't turn on. Power supply issues? Thanks
                                    • pansatdishman
                                      • Jun 2013
                                      • 110
                                      what should i try next thanks?
                                      • GLISIT
                                        by GLISIT
                                        01-16-2025, 02:29 PM
                                      • justice171
                                        Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                        by justice171
                                        I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                        Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                        1. Verified that all critical voltages are present:
                                          • 3.3V and 5V are always present if DC is plugged.
                                          • 1.8V on the BIOS chip is present.
                                        2. Checked the power button functionality:
                                          • When pressed, the voltage drops to 0V, indicating the button is functional.
                                        3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                          • Confirmed connectivity is intact, ruling out issues
                                        11-26-2024, 12:39 AM
                                      • claws77
                                        lenovo flex 5 14itl05 power sequence issue
                                        by claws77
                                        hi guys, my motherboard will not start no matter what
                                        when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                        but rest nothing happens no sign of life.
                                        this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                        with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                        but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                        i have no knowledge of motherboards ....
                                        10-20-2024, 02:48 PM
                                      • SuperJames
                                        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                        by SuperJames
                                        This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                        Specs
                                        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                        Backstory
                                        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                        10-23-2023, 04:09 PM
