Toshiba 19w330db backlight flashing problem
+ More Options
Posts
  • John843883
    • Nov 2012
    • 71
    A friend sent me a video of a fault his TV developed. Haven't physically looked at it yet but I'm assuming backlight CCFL going out, cracked solder joint/loose grounding screw or capacitors? Almost looks like the backlight is flashing white every so often.
    Here is the video clip he sent me: https://imgur.com/a/OtKcEPQ
    Anyone seen this sort of thing before? TV is a small Toshiba LCD probably from around the mid 2000's when LCD's like this were becoming affordable.
    Any hints/experiences with this sort of symptom would be appreciated!
    Thanks.
    Last edited by SMDFlea; 11-04-2020, 11:29 AM. Reason: Renamed thread title,added model number
  • John843883
    • Nov 2012
    • 71
    Re: Toshiba backlight flashing problem
    Update: It's model number is 19w330db and shaking it physically doesn't seem to change anything.
    • learnmore
      Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
      by learnmore
      Hello Community!
      CASE DETAILS
      Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
      13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
      Tried inserting firmware on USB and left it in for a few hours, but no change
      03-03-2024, 09:49 AM
    • HTR-Informatique
      by HTR-Informatique
      02-09-2025, 06:51 AM
    • Dobrowol
      Asus GA402RK keyboard and kb backlight problem
      by Dobrowol
      Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
      04-28-2025, 04:30 PM
    • ononos
      LG M2362DP Backlight problem
      by ononos
      hello everyone!
      As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
      I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
      So i decided to try to...
      03-12-2023, 05:05 AM
    • fanaticgames
      Samsung UE32D4010 Backlight problem, led ok
      by fanaticgames
      hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
      02-22-2023, 09:46 AM
