panasonic tx-p50gt30 8 blinks afrer 7 blinks repair
  • dj01fad
    • Sep 2014
    • 92
    • romania
    Hello again.
    I have a little problem with my tv: it had the 7 blinks failure, and I repaired the SC board. After that, it starts for 1 second and goes to 8 blinks. Everything on the SC board looks to be fine but I discovered that I have one shorted transistor on the SS board, Q102. I have a new one but I am wondering if it would be better to replace also IC 191.
    I did not check the SS board before the 8 blinks. Do you think it's possible that it went off together with the SC board or it died after my repair?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: panasonic tx-p50gt30 8 blinks afrer 7 blinks repair
    You should be fine with replacing Q102 only. I've had this fault myself.
    • dj01fad
      • Sep 2014
      • 92
      • romania
      Ok, thanks. I'll give it a go.
      Have you found the cause of this double failure?
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Just the loose screws that mount the boards.
        • dj01fad
          • Sep 2014
          • 92
          • romania
          Yeeeee! It's alive!
          It was only Q102 on the SS board.
          The SS screws were not loose. On the SC yes, they were loose, almost all of them. I had some screws with washers and replaced all of them.
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            Good job! Those damn screws have kept a pretty good supply of cash coming my way.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
              by sam_sam_sam
              After all of...
              07-13-2024, 08:14 PM
            • canadaboy25
              Panasonic TC-P54VT25 No image. A or D board?
              by canadaboy25
              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
              The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
              01-17-2021, 01:06 AM
            • Biruslapio
              Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
              by Biruslapio
              Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
              It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
              It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
              02-16-2021, 09:44 PM
