Cello P50ANSMT-4K won't boot to Android but ok on HDMI
  • Neilgw
    • Oct 2020
    • 13
    Re: Cello P50ANSMT-4K won't boot to Android but ok on HDMI
    That only seems to turn on the set, if I press source 2580 I get a factory menu? see pics.
    I've tried the factory reset in this menu
    • Diah
      • Feb 2013
      • 6397
      try first shipment Init.. if no change then Factory reset
      • Neilgw
        • Oct 2020
        • 13
        Tried that and no change, just puts the screen black after a few seconds
        • Diah
          • Feb 2013
          • 6397
          okay, after the screen goes black and then on exit the service menu by unplug it from wall socket... then plug again... did the first installation showing to you?
          how about if you click on swupgrade what it show to you
          • Neilgw
            • Oct 2020
            • 13
            when plugged back in get please wait in screen then black, no sw upgrade option in the factory menu the option SoftwareUpdata 6m60 does nothing sw version just give the info in the image.
            • Diah
              • Feb 2013
              • 6397
              you may have HW issue or BGA at the main IC as it control all input sources include Tuner.
              or could be too the tuner defect.. so or so need really deep inspection. but starting from BGA issue will be essential for the rest work. but blaupunkt famouse with rubbish firmware.. reset solve many problem.. not yours lol ... sorry i am out of any further idea.
              • Neilgw
                • Oct 2020
                • 13
                Thank you for trying, I will try and read the firmware from the headers on the board I think there are 2 points 3.3v and a 5v header I will try with usb serial see what I get and take it from there.
                Once again thank you for your help.
                  LCD LED TV Service Menu Codes
                  ALL LCD LED TV SERVICE MENU CODES
                  Service Menu Code with Board Name
                  China Universal Board / Jumper Board Service Menu Code
                  Changhong Ruba Service Menu Code
                  Ecostar LED TV Service Menu Code
                  Orient LED TV Service Menu Code
                  Haier LED TV Service Menu Code
                  TCL LED TV Service Menu Code
                  Samsung LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  Videocon LED TV Service Menu Code
                  Supra LED TV Service Menu Code
                  Toshiba LED TV Service Menu Code
                  Symphony LED TV Service Menu Code
                  Veste/ LED TV Service Menu Code...
                  10-31-2024, 03:58 AM
                • Grut
                  JVC LT-39CA120 - Vestel 17MB171 - Android boot loop
                  by Grut
                  My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
                  Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
                  When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
                  Can anybody help me please finding the 17MB171 USB firmware to try to upload...
                  11-15-2024, 03:12 AM
                • jchon
                  How do modern TVs with Android/WebOS/Roku/etc boot? Debug ports?
                  by jchon
                  Hi I'm having issues trying to get my Sony A1E to power on.
                  Which made me wonder, how involved is Android in the booting of the TV?
                  I'm basing this information on what I can glean from the service manual:
                  In my Sony A1E for example I see:
                  BKA which houses the main processor and along with the input/outputs.
                  DKA which possibly does up-conversion, in the block diagram I see VX1 coming in from the BKA and out to the TCON
                  TCON timing board which drives the actual panel.
                  On the BKA there's a sub-system called the U-COM...
                  06-30-2023, 01:58 PM
                • JaquesPratt
                  Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                  by JaquesPratt
                  I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                  This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                  07-16-2024, 01:04 AM
                • eltano4i20
                  [HELP] SAMSUNG NP270E4E-K01AR
                  by eltano4i20
                  1) Error trying to enter the BIOS
                  --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                  Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                  BOOT PRIORITY ORDER (img-05)
                  1- Windows Boot Manager
                  2- SATA HDD
                  3- NETWORK
                  4- Debian
                  2) Error trying to access the BOOT MENU
                  --> I restarted the notebook and pressed [F10] but the BOOT...
                  07-04-2025, 12:39 AM
