Cello P50ANSMT-4K won't boot to Android but ok on HDMI
  • Neilgw
    • Oct 2020
    • 13
    Hi, this is my first post and just hoping someone can point me in the right direction.
    I've got a Cello P50ANSMT-4k, mainboard model MSD3458.c1v5.0, the set switches on fine and get please wait on the screen then just a black screen but the menu's still work and can still use HDMI with a fire stick etc.
    Cello sent me an update but I'm unable to get it to take it from numerous usb sticks and in all sockets, tried to do it from the menu and by pressing vol up on start up. I've also been into the engineer menu and done a reset but no luck.
    Has anyone any ideas? it seems to be just the Android os that is corrupt?
    Any help would be appreciated.
    Neil
  • Diah
    • Feb 2013
    • 6399
    Re: Cello P50ANSMT-4K won't boot to Android but ok on HDMI
    from yours explaining of the issue. you have now lock system or hotel mode lock on.
    go to go lock setting and clear all default password 0000 master password 8899.
    also you can go to setup setting and clear all to default will reset your tv firmware
    • Neilgw
      • Oct 2020
      • 13
      Hi Diah,
      I checked and hotel mode is off, I've cleared all and in system restored default but still the same
      • Diah
        • Feb 2013
        • 6399
        Originally posted by Neilgw
        Hi Diah,
        then try hard reset.. while its on unplug it from wall socket. ON the TV side panel not on RC press power and volume down , keep press them for enough time while you unplug it to wall again.. this is procedure for android Sony 4K hope it will work for you too.
        • Neilgw
          • Oct 2020
          • 13
          That just makes the tv power cycle till I release the buttons.
          • Diah
            • Feb 2013
            • 6399
            could you upload photo over here to yours side control panel..?
            did you have front LED indicator on the tv.?
            • Diah
              • Feb 2013
              • 6399
              BTW: maybe yours pressing was so long to bring it to power cycle.. try to release power and remain volume down pressed as long the logo showing on the screen
              • Neilgw
                • Oct 2020
                • 13
                I've tried holding the Vol down and power till please wait appeared the released the buttons but the tv just stays on the black screen.
                • Diah
                  • Feb 2013
                  • 6399
                  please wait mean it will inter recovery where we can reset and clear cache
                  i just learned this Cello are Blaupunkt. you could find reset hole or key on the main boards..
                  about update didn't run. the most issue are on the USB stick or the PC. USB stick format fat32 till 4Gb or less enough... on PC need to enable showing all hidden file ( some pc after formatting the stick they generate hidden file under name system volume information ) this file need to delete.
                  also on PC setting to show file extension too such .bin .exe etc. so you can see that the files didn't had any double extension
                  • Neilgw
                    • Oct 2020
                    • 13
                    Ive tried 4 usb drives fat32 show hidden files and file extensions no other files on the drives and tried all usb ports. the file they sent me is mstarupgrade.bin
                    pics attached of button panel and mainboard
                    • Diah
                      • Feb 2013
                      • 6399
                      you wrote at yours first post plying signal via HDMI okay.. did you try to play media with USB or SD card such as photos .jpg or movies ? you should try to play media via USB SD card to know that main boards doesn't locked only on HDMI source.
                      • Neilgw
                        • Oct 2020
                        • 13
                        Yes can play music and photos via usb but cant see update file.
                        Tv is functioning fine except for Android and TV tuner
                        • Diah
                          • Feb 2013
                          • 6399
                          try use the SD CARD slot for update
                          edit ; on the MB you have near the NAND socket with 2 pins ist written UPGRADE ?
                          • steviewonder
                            • Dec 2013
                            • 183
                            • england
                            The usual Means of upgrading firmware on Cello/Blaupunkt is to put the update on formatted fat32 memory stick (use the smallest size mem stick you can find,many sets will reject anything over 8gb,insert the stick,then switch the set on at the wall.If the front light starts flashing,this means the upgrade is being accepted.
                            • Neilgw
                              • Oct 2020
                              • 13
                              Diah, yes 2pin header upgrade.
                              steiewonder, Ive tried 2 x 8gb usb drives 1x 16gb drive 1x 32gb tried from sdcard also tried from bootup and from the menu but no joy but all cards work with music or photos etc.
                              • Diah
                                • Feb 2013
                                • 6399
                                please read the voltage on the 2 pins while the set on.. black probe to tv chassis.. also when you plug it out from wall socket read the pins with Ohm between each other and between each and chassis
                                • Diah
                                  • Feb 2013
                                  • 6399
                                  rename mstarupgrade.bin to upgrade.bin and try from menu or from off wall socket
                                  • Neilgw
                                    • Oct 2020
                                    • 13
                                    Tried rename to upgrade.bin no change, voltage on pins left pin 5.23v right pin ground with tv powered on
                                    ohms is reading 151.9 pin to pin and left pin to chassis right pin is ground
                                    • Diah
                                      • Feb 2013
                                      • 6399
                                      okay, this bring nothings since we don't have the service manual..
                                      let try to inter the service menu. try to press on the side panel the standby 5 second long..
                                      • Diah
                                        • Feb 2013
                                        • 6399
                                        or on RC press menu then 1147
                                        or on RC press AV then 2580
                                          LCD LED TV Service Menu Codes
                                          TCL LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          10-31-2024, 03:58 AM
                                        • Grut
                                          JVC LT-39CA120 - Vestel 17MB171 - Android boot loop
                                          by Grut
                                          My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
                                          Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
                                          When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
                                          Can anybody help me please finding the 17MB171 USB firmware to try to upload...
                                          11-15-2024, 03:12 AM
                                        • jchon
                                          How do modern TVs with Android/WebOS/Roku/etc boot? Debug ports?
                                          by jchon
                                          Hi I'm having issues trying to get my Sony A1E to power on.
                                          Which made me wonder, how involved is Android in the booting of the TV?
                                          I'm basing this information on what I can glean from the service manual:
                                          In my Sony A1E for example I see:
                                          BKA which houses the main processor and along with the input/outputs.
                                          DKA which possibly does up-conversion, in the block diagram I see VX1 coming in from the BKA and out to the TCON
                                          TCON timing board which drives the actual panel.
                                          On the BKA there's a sub-system called the U-COM...
                                          06-30-2023, 01:58 PM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
                                        • eltano4i20
                                          [HELP] SAMSUNG NP270E4E-K01AR
                                          by eltano4i20
                                          1) Error trying to enter the BIOS
                                          --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                                          Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                                          BOOT PRIORITY ORDER (img-05)
                                          1- Windows Boot Manager
                                          2- SATA HDD
                                          3- NETWORK
                                          4- Debian
                                          2) Error trying to access the BOOT MENU
                                          --> I restarted the notebook and pressed [F10] but the BOOT...
                                          07-04-2025, 12:39 AM
