Samsung Plasma PN58B860Y2F low vscan
  • xrey
    • Oct 2020
    • 5
    • usa
    We all of the sudden started getting a washed out picture and rainbow colored static/snow.
    When we tested vscan, etc., everything measured properly but not the vscan.
    Supposed to be -193 got -93 (tested it w the TV on)
    Researched it and decided to replace the y board and y buffers.
    Now I get no picture or sound - TV turns on but nothing else.
    When I run the same tests I am still getting -93 on the vscan test and this is now a different Y board, buffers, etc.
    So I am thinking either I did something wrong originally in how I did or interpreted the -93 reading - or this y board is having the exact same issue.
    Multimeter was set to 200 on the left hand side (there is a V with a - and ... underneath).
    May or may not be relevant: in 2013 I had to replace the main board << may not be exact correct term - the one the HDMI is on. At that time I think the symptom was constant clicking from the TV. Has been working perfectly until this now happened.
    What do you think I should try next or do?
    Thanks very much.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Samsung Plasma PN58B860Y2F low vscan
    Do you have any high resolution photo's of your boards which could help people to work out where you should measure Vscan?
    • xrey
      • Oct 2020
      • 5
      • usa
      Thanks dick_barton
      I'm willing to post a picture if that would help, for sure, the thing is, I'm pretty certain I am measuring at the right spot because Vs, Va, Vscan, etc., are clearly labeled on the board.
      I'm wondering if a better question or better way to ask would have been just that I replaced the Y boards and Y Buffers and now not getting picture and sound.
      I'll post it though if you think that would help.
      • Hamie
        • Apr 2014
        • 1383
        What's the vscan with the buffers disconnected?
        • xrey
          • Oct 2020
          • 5
          • usa
          Saw this real late - will try tonight tonight or tomorrow.
          What could I expect to find or figure out if it's different?
          Also - I remember reading that for some measurements you need to have the TV on for at least 15 minutes to get a true reading. Does that apply to the vscan reading?
          Thanks @Hamie
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • ohren
            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
            by ohren
            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
            The models launched in 2018 and 2019 respectively....
            09-08-2023, 05:24 PM
          • C152Heavy
            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
            by C152Heavy
            Summary for TL-DR readers:
            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
            • Have obtained Samsung schematic & service documents - Can upload if helpful.
            • Have read ALL applicable threads
            • C1818 and CP820 replaced as low hanging fruit
            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
            • VCC pin (18) of PFC...
            01-11-2023, 02:53 PM
            09-07-2024, 05:50 AM
