Hi there, anyone has se55gy01uk eeprom dump file? Couldn't find it anywhere, tv stuck on seiki logo bootloop
Seiki tv dump file
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by kenzo2I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
I need dump file MACBOOK PRO A2159
TSB4232(256)
TSB4229(256)
Thanks​ -
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
- Loading...
