Many boards and parts for TV repair
  • jason123
    • Oct 2015
    • 1154
    guys not sure this is allowed... but i have tons of boards and cables for TVs that i would like to sell. Check eBay (compsp) and see whats listed. Thats a fraction of what i have.
    Just getting out of the business. $100 all plus $65 shipping (will be very heavy box)
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Many boards and parts for TV repair
    there is a classified section for sell / trade here on badcaps.
    • ugamazing
      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
      by ugamazing
      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
      12-17-2024, 07:05 PM
    • ugamazing
      Apple M1 Boards & Exclamatory Error?
      by ugamazing
      We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
      Has anyone else run into this...
      02-20-2025, 09:24 AM
    • H H
      3090 FE Part Confirm/Identification
      by H H
      I'm hoping someone could help me confirm if I have identified the following parts correctly.
      Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
      The parts needing replacement are on the back of the board behind the HDMI input.
      I have identified the parts as the following:
      C6037: MLCC 0.1uf/16v(0402)x7R W05
      R6016: RES 499 OHM 1/16W (0402) 1%
      LB10911: Ferrite Bead (0402)...
      02-16-2025, 01:09 PM
    • Mark D
      Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
      by Mark D
      The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
      10-29-2024, 03:15 PM
    • ugamazing
      Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
      by ugamazing
      I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
      08-31-2022, 07:34 AM
