LG 47LE8500 - Stuck Logo - Solution
  • letmefixit
    • Sep 2020
    • 10
    • usa
    All,
    If you have this TV and stuck at the Logo, it might be due to firmware. You can download the firmware from LG and put that in a USB (formatted as FAT32) under directory LG_DTV.
    1. Switch off the TV
    2. put the usb with the bin file in the usb port
    3. remove all other wires - IMPORTANT
    4. switch on the TV. ( it took couple of times before it loaded the firmware and TV started working).
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: LG 47LE8500 - Stuck Logo - Solution
    By other wires, do you mean HDMI and rca wires?
    • letmefixit
      • Sep 2020
      • 10
      • usa
      Only USB and power cord should be connected. All other cables like HDMI, RCA, Antenna, etc should be disconnected.
      • Daniel Larsson
        Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
        by Daniel Larsson
        My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
        I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
        During these seconds the function button is not working...
        08-13-2025, 10:29 AM
      • mr.Data
        Macbook A1990 stuck on logo
        by mr.Data
        This Macbook Pro 2018 boots up and then gets stuck on the logo.
        All the normal methods of resetting this Macbook have been tried but do not work.
        I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
        Any help would be greatly appriciated....
        04-18-2024, 11:51 PM
      • platinumsteel
        Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
        by platinumsteel
        Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
        03-18-2024, 05:16 PM
      • digtalhd
        Dell Inspiron 7490 Stuck on Dell Logo
        by digtalhd
        Hi!
        Anyone hepl me! My laptop stuck Dell logo after I clear ME.
        Dell Inspiron 7490
        S/N: 28760285127
        LA-H451P Rev: 1.0
        Thank!...
        11-13-2024, 10:17 PM
      • Raymond red (mon)
        Brother J2730-DW stuck on Brother Logo
        by Raymond red (mon)
        hello, I have this Brother J2730-DW printer that was brought to me by a friend, it was supposed to be converted to continues ink but the printer wouldn't turn on completely. The printer powers on and plays a tune but it gets stuck in the brother logo. Upon checking, the printer was infested by many small cockroaches. I do checked the board cleaned and tested some corroded capacitors but all seems to be fine, I couldn't find any short circuit or any missing component on the board. Also checked the power supply and it was working fine.
        please help.
        11-08-2024, 09:19 AM
