KDL-60EX700 7 Blinks
  • Plurxtc1
    • Oct 2014
    • 136
    I got a Sony TV that keeps going off after 45 minutes to an hour. When the TV goes off it doesn't flash the red indicator. I am assuming the indicator stops flashing after a certain amount of time. I know the flashes is 7 because I went through the error code menu. Remote: Display, 5, Vol -, then power. It labeled TEMP with a number 7 next to it. Does anyone have any ideas what this maybe? When it plays it looks perfectly and no imperfections, and no the TV is not dusty.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: KDL-60EX700 7 Blinks
    From what you say looking like an over temperature shut down. What , I don't know but perhaps the manual can tell you what temperature sensor is monitoring.
      Try disconnecting the HLR board.
      • Plurxtc1
        • Oct 2014
        • 136
        Disconnecting did fix the issue but the downside is that I can't use the remote
          You can still use the HLR board by disconnecting the RGB sensor, show good clear pictures of the top and bottom side of the HLR board, or order the replacement.
          • jean luc ferre
            acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
            by jean luc ferre
            on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
            i tried the hard reset, cmos reset, changing the ram without results.
            in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
            The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
            but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
            11-22-2025, 03:54 PM
          • Biruslapio
            Panasonic P58V11B 8 and 12 blinks error "fix"
            by Biruslapio
            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
            04-13-2021, 07:13 AM
          • Nairolf
            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
            by Nairolf
            I have a Samsung DM32D display.
            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
            Here’s what I have tried so far:
            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
            From these tests, I suspect the problem might be on the mainboard. Could anyone...
            08-24-2025, 03:47 AM
          • Andre Gilbert
            by Andre Gilbert
            11-20-2024, 08:52 PM
          • Userrrname
            Tx-pr42gt30 6 blink
            by Userrrname
            👋🏻I recently got a tx-pr42gt30, I bought it in non-working condition. When I opened it, I saw that all the transistors and diodes had been removed from the tnpa5330, and several microcircuits were in poor condition, so I decided not to try to repair it. Instead, I bought another tnpa 5330 (also AB), which was already repaired (according to the seller, the board was repaired and worked before the screen was damaged), transistors were also changed on it, but Chinese copies were installed (there is no round hole in the middle, the inscription is easily erased) and a pair of transistors that...
            07-19-2025, 07:53 AM
