lg tv problem.... 2 tv 2 different problem
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    hi all, i got 2 tv for repair as they had both backlight problem.
    1st tv is a lg 32ln536b and after some investigation i found some led was bad, so i replaced them, but when glue the thing in front of the led, now i have that led visible on the screen. i tried different height from led strip to that thing (dunno its name) but same problem, do i need to make them perfect centered, perfect height or what is wrong ? im thinking in buy all new led strip for around 27€ (yes they are cheap) and see if i get away of that problem, but would like to know if that lg need some care to take of to make them be like normal when u need to change just some led. i did a samsung led repair and it went perfect. changed 5 leds on that samsung and had no problem.
    2nd tv is an lg 22 inch . backlight went off after a while and get off more fast if i put backlight on max, but didnt even notice that light increase or decrese at all.
    i ordered 4 ccfl brand new, and when disassembly the tv i noticed 2 of the old ccfl had black spot on the edge, so those were defective or the cause of the problem. i changed the 4 ccfp (pachage of 2 each side) and the work went really smooth as the new ccfl comes with the backplate already on them.
    i reassembled the tv (blue ccfl or pink ccfl need to be in the exact old position?) , turned on and even if backlight value was not giving the sensation of increase or decrese like before, i set it to 67% and tv looks perfect like new. totay i used it for watching news and after approx 8 min i started earing a buzz noise from it. turned of and on and buzz was already making noise.. this time i turned off waited 2 mins turned on again and no buzz this time, but after again 7-8 mins it started the noise.... i went on menu and i noticed that if i get backight over 75% ithe buzz noise go off, but why that ? ccfl making some strange contact with the plastic inside lcd or is some diode , transistor or what else making it ?
    edit: i think that the buzz noise are the ccfl touching something as i didnt use original plastic and metal they had and went strait using those who came with as more clean and more easy.
    anyone encountered the same situation before ?
    tnx everybody for helping for both case.
    i preferred to open a single post, because both tv works and dont need big repair.
  • neilc6
    • Nov 2015
    • 1550
    Re: lg tv problem.... 2 tv 2 different problem
    The lens needs to be perfectly centered or it will cause halos or bright spots. You can turn on the TV with the panel disconnected and replace the diffuser panels to check before final assembly. I don't do replacements if the new strips can be found. All the LEDs have wear and are likely to fail in the near future.
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      tnx for the advice
      • courtcircuit
        Philips HTS8000 home cinema noise problem
        by courtcircuit
        Hello
        I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
        Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
        Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
        I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
        Removed each of tyhe boards
        02-08-2025, 08:22 AM
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • Zeonalbasta
        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
        by Zeonalbasta
        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
        09-13-2024, 01:17 PM
      • tony359
        by tony359
        11-28-2023, 05:18 AM
