Sanyo AVM278 chasis: DS25390 -- no sound on cable input only
  • Kevin O'Henly
    Ontario Member
    • May 2009
    • 48
    ...decided to take a break from flat screen computer monitors and look at a Sanyo AVM278 TV.
    The RCA jack inputs reproduce good, clear sound & picture but the cable input does not have any sound.
    This is the first TV I have looked at since the glass tube models and I could realy use some assistance.
    Pictures in the next post.
    THX
    Be yourself,
    everyone else is taken.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Sanyo AVM278 chasis: DS25390 -- no sound on cable input only
    set to sap when none present?
    • Kevin O'Henly
      Ontario Member
      • May 2009
      • 48
      Thank you for your great suggestion, kc8adu.
      It can not be that easy!
      I will check the set and post.
      rgs,
      Kevin
      Be yourself,
      • Kevin O'Henly
        Ontario Member
        • May 2009
        • 48
        This model does not seem to have an SAP setting.
        The closest setting in the menu system is labeled "AVI".
        I went through the menu and set/reset every setting I could find (including the volume) with no sound from the cable feed.
        The largest IC on the circuit board in chassis DS25390 is labeled OM8377PS.
        The only SANYO schematic I could find is the: DS20930 chassis service manual which uses the LA76950 control IC.
        While these IC's are likely to have similar functions they do not seem to have similar pin outs.
        I need to know which pins on the OM8377PS are the MUTE binary input and FM-AMP (audio) output. I can trace it around from there.
        THX,
        Kevin
        Be yourself,
        • mockingbird
          • Dec 2008
          • 5488
          This TV is a piece of trash.
          I picked it up from the trash this summer and it never worked properly. Kept shutting itself off. Replaced all the caps and then the screen turned green.
          Junk it. It uses a Samsung tube, and the image quality quite frankly stinks.
          I spent $40 on it and it's about to go in the trash. The hoarder in me wants to take out the motherboard again to salvage the caps I invested but I think I'm just gonna throw it away next week.
          • Kevin O'Henly
            Ontario Member
            • May 2009
            • 48
            THX mockingbird,
            I have decided to purchase a digital tuner for it and use the audio inputs.
            Any one know where I can pick up a thrifty tuner?
            If you still have the board then I could realy use the audio preamp IC part number. It's the tabed 8 or 9 pin single inline device in the located in the middle area of the board.
            Best regards,
            Kevin
            Be yourself,
            • mockingbird
              • Dec 2008
              • 5488
              Let me check...
              ST e3 PHL
              TDA8145
              7B244530
              • hugocarmo
                Panasonic TX-24A1UN CRT Sound and Input problem.
                by hugocarmo
                Hi.
                I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
                It is imaculate inside, almost no dust or debris inside.
                The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                So I started to look for a service manual, I found one, and started from the beginning.
                Most of the times the caps are the problem so I orderer all the caps for all boards,...
                04-26-2025, 07:45 PM
              • Sushi1808
                Onkyo TX-NR609 Sound only on USB/Internet Radio/DLNA Input
                by Sushi1808
                Hi everyone!
                I turn to you in hope someone could point me in the right direction since I lack knowledge and experience in diagnosis of audio equipment. (My experience is in computer chip level repairs.)
                I bought an Onkyo TX-NR609 receiver which initially produced no sound on speakers/headphones, there was no delayed relay click, speaker matrix icon didn't show up, USB/NET stuck in "Now initializing", instead of DSP/1st NET firmware version there were ?????????...
                There was flux residue around the D830K013BZKB4 DSP chip (Q3001) on the HDMI...
                07-01-2023, 07:53 AM
              • hugocarmo
                Sanyo VHR-D4710G VCR no sound.
                by hugocarmo
                Hi again guys.
                Today I have a problem with this Sanyo VCR.
                I bought it online, It worked sometimes.
                I recap the Power supply and it started working fine.
                Image is perfect and all digital effects too.
                All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
                I have no sound on playback, on tuner, or aux in.
                On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
                On one of the sound processing...
                01-23-2024, 12:58 PM
              • ugamazing
                820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                by ugamazing
                So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                04-10-2024, 08:06 AM
              • dreamlayers
                Weird clipping on Logitech Z-10 speakers
                by dreamlayers
                I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                05-22-2025, 11:41 AM
