Vestel toolbox 1.1 profile change will not work?
  • l3emarsh
    • Jul 2020
    • 28
    • england
    Hello all,
    I have a 55" 4K HDR Smart tv which is Panasonic but has a Vestel 17mb130s main board and it crashed resently, with the help of Diah in my first thread I loaded new firmware but from a Finlux tv and it worked and I have been using it since then.
    my problem is that it has no freeview play and its starting to piss me off as there is a lot I cant watch.
    In the profile I downloaded from the service menu onto usb stick I changed the option for Freeview Play from off to on and I can't seem to upload the profile back onto the tv as each time I try the service menu say's the Freeview Play is off?
    Because of this I have two questions,
    1= can anyone give me the correct procedure to download change and upload the changed profile after using vestel toolbox 1.1 to change the Fplay to ON, including the things in vestel toolbox I have to change as I have a feeling that's more that just off to on.
    2= as this tv takes different makes of firmware, What is the Latest and BEST firmware I can instal to a 55" 4K HDR Smart TV which has a Vestel 17MB130S main board inside? Because I think I could have a very good setup with all the latest and best app's and menu options if you understand what I mean, so with that in mind what are my options?
    I will be very greatfull to anyone who can help me with either of the above problem's.
    Many Thanks Lee.
  • Diah
    • Feb 2013
    • 6355
    Re: Vestel toolbox 1.1 profile change will not work?
    just notice this points. i will try to help with my limited time.
    A-after modified any profile .bin file you need to put the file on the USB inside the folder Profile
    and on the root of the USB should have only one file which you generated first time to download the files
    B- After write any file back to the TV via points "A" ..you need to reset the the TV from the installation menu . so the change will take effect.
    your questions. No 2.
    All brands share same firmware.. but there are some futures hidden (disabled ) regards brands as you described above.
    you can also activated the Dolby Vision and many others. but some change need to modify the swprofile.bin & hwprofile.bin & others to match each others.
    you can zip all profiles file you got at first time via service menu and upload them over here to take look and modified them for you as full futures when i get free time.
    • l3emarsh
      • Jul 2020
      • 28
      • england
      Diah,
      As requested I have uploaded the three profile files here in the RAR file for you to look in to for me when you get time and I would like to thank you in advance for doing this for me.
      Lee.
      • Diah
        • Feb 2013
        • 6355
        Originally posted by l3emarsh
        Diah,
        Lee.
        this is first version of mode.. do it with breakfast before go to work...lol and because i don't know which generation of CPU yours MB had. so many things i avoided in order not great overload on the SOC i don't know .. keep yours file profile always as backup.
        write all 3 files at once to the tv .. then rest ,, go to menu ---- installation--- factory reset .. test and report the result. BTW: don't surprise if you saw different design.
        • yokoono
          • Apr 2010
          • 479
          1. Create a folder on the stick called PROFILE
          2. Copy the modified profile into it
          3. Turn on the TV and insert the stick
          4. Type MENU 4725
          5. Go to USB Operations and type OK. Wait 5 seconds
          6. Go to Diagnostics and type OK and then 2 times BACK (RETURN)
          7. Exit the menu and turn off the TV on the remote control
          8. The left LED flashes quickly. The modified profile is now loading.
          9. Wait until the LED stops blinking and remove the stick.
          10. Turn on the TV.
          • l3emarsh
            • Jul 2020
            • 28
            • england
            Hello fellow tech heads........
            I have tried everything posted here and more to try and get the profiles to upload back onto the TV but I just can't get it to work and I have now run out of ideas.
            The problem seams to be what to put onto the stick to get them to upload when I am in the service menu under USB operations as when I do that I don't think it's working as it should?
            Will it make a difference now it's a Finlux setup now and not Panasonic?
            Any help or other ideas would be very greatfull, thanks in advance and I am sitting here waiting to try your ideas now as I cant stop trying to win and not let this TV problem beat me as you know too well so please post back asap please.
            Thank You All, Lee.
            • l3emarsh
              • Jul 2020
              • 28
              • england
              Also can anyone tell me what to change in vestel toolbox so I can watch a different channel whilst recording one
              And what to change so I can use my original Panasonic remolt control from the original TX-55FX555b setup the TV came with as my Universal remolt control I got for this Finlux setup has no button for stop start play pause fwd rew when playing recordings, well I can play them but only way to stop once started is to turn off TV?
              Or has anyone got a profile setup from that type of Panasonic and ill check the remolt control codes in toolbox myself.
              Thank You.
              • Diah
                • Feb 2013
                • 6355
                Thank You.
                good.. it sounds you figured out how to write back the swprofile.bin back to the tv..
                swprofile even if you use one from other brand from same family MB100 will be suitable the setting of it to do it on yours... but... let answer yours questions..
                1-PVR+TwinTuner
                2-RC to mapping it to yours panasonic. with same tool you can enable ftp on the tv and use any ftp client to log in via yours home network inside the tv firmware...... i will stop here to avoid you make damage..as this steps are suitable only to users have knowledge of linux firmware ( who knows linux don't need one explain to him)
                3- never touch or do any change at hwprofile.bin.
                • l3emarsh
                  • Jul 2020
                  • 28
                  • england
                  I have finnaly worked out how to upload the profile files and it was working but where I was getting confused was that my TV did not have a reset or factory reset in the normal menu, what I had to do was to paforme a first time instulation which is same as reset but just was not listed as that but I got that sorted anyway so thanks to all.
                  But I still have the r/c problem and could do with the Panasonic r/c code, or if anyone has a copy of the Panasonic profile I can look up the codes from Vtoolbox, I will give you the panel code but I think most Panasonic TV's are on simular r/c but it will not hurt to try if you do.
                  17MB130S
                  VES550QNYS-2D-NO1
                  any help is greatfull, thank's, Lee.
                  • Diah
                    • Feb 2013
                    • 6355
                    17MB130S
                    VES550QNYS-2D-NO1
                    okay do it on your own risk... however its easy and just need to be focused.
                    at your case open mb130_hwprofile.bin with the tools
                    go down to RemoteControl and expand the tree list of it.. remark your remote name from the list.. there are 2 of panasnoic but it maybe there more.
                    on the pc open the file "dictionary.ini" with editor i prefer Notepad++
                    search after the name of the remote list you want to use for example PANASONIC-Rc4812x you will see at dictionary.ini like this
                    Code:
                    [3D51DA20]
                    value=PANASONIC-Rc4812x
                    always the native code are on the top and follow the name translation of the code.
                    so you have
                    3D51DA20 are the native code .. copy it and change the last one "RcType" with his code 3D51DA20 save and write it back to tv
                    EDID: IMPORTANT
                    we dont know at this point what is written at the firmware of RC code... if its native or string.. so if its native then it will work.. but if its string then you need to write at RcType the string which are listed under the RemoteControl list in your case PANASONIC-Rc4812x ... try this option first please its more save to you.... as the first option if it make the tv will not response to rc then need to flash the whole firmware again as you was at brick.
                    • Diah
                      • Feb 2013
                      • 6355
                      EDID: IMPORTANT it make the tv will not response to rc then need to flash the whole firmware again as you was at brick.
                      to any user read this don't follow my post above it was explaining not as resolve problem.. mapping the RC only will be succeed by log inside the firmware and change the remote.config at etc users..
                      changing the code at hwprofile will make the TV blind. because this change will never make change to the main config at etc user..
                      i put this again..to let reader don't mistake my previous statement.
                        LCD LED TV Service Menu Codes
                        TCL LED TV Service Menu Code
                        LG LED TV Service Menu Code
                        10-31-2024, 03:58 AM
                      • piernov
                        Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                        by piernov
                        Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                        I suspect corrupt firmware but I haven't been able to find anything for this TV.
                        TV model: Finlux 65-FUC-8060
                        Mainboard: Vestel 17MB130S 23473048
                        Panel: VES650QNTS-2D-U11
                        At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                        06-01-2024, 12:57 PM
                      • Liammif
                        Vestel 55” 17mb130s help needed
                        by Liammif
                        I have a vestel 55” chassis VES550QNDS with 17mb130s main board, the tv brand is Teac and its the LE55A4S1UHD. Originally had blinking standby light of death. Tried a panasonic firmware which worked, loaded to language page and I had thought it was frozen, turned out the remote obviously didn't work because it was panasonic firmware (stupid me). I tried loading another firmware I was sent which corrupted or something and now as soon as the tv is plugged in it does the blinking standby light straight away without trying to power on. I can hold the ok button on my remote when I first plug the...
                        09-01-2021, 05:55 AM
                      • John843883
                        Toshiba 19W330DB (Vestel 17MB24H-2 190407) freeview/DTV not working
                        by John843883
                        Hi, got a friends older (2007-08) bedroom LCD TV here and the freeview/DTV has stopped working and just displays a black screen with occasional flashes of green or reddish-pink near the top of the display. Apparently it just went without any prior warning signs.
                        Other inputs appear to work fine and when switched to analogue (this is an old TV) I get the regular snow pattern so I don't think it's the screen itself. Can't test a true analogue TV signal since analogue TV was switched off years ago in the UK.
                        I've taken the back off and reseated every connector and prodded...
                        01-04-2023, 05:46 PM
                      • l3emarsh
                        panasonic vestel tv turn on alexa in service menu
                        by l3emarsh
                        i have a panasnic vestel tv and need to turn on alexa option using vestel software programming, using usb stck to reprogram software via tv usb port onced changed
                        Please help me as i cant remember how to do it.
                        all help is greatly appreciated
                        01-02-2022, 10:50 AM
