Basic Display Power Supply
  • jason123
    • Oct 2015
    • 1154
    Hi Folks,
    I posted a problem in the Troubleshooting Computer Displays (https://www.badcaps.net/forum/showthread.php?t=88070) but I think that forum is for operational troubleshooting?
    If someone from the TV and Video sources can take a look I'd appreciate it.
    I just would like to know why I'm not getting any voltages on the cold side for the power board. The large cap has 160V
    03-31-2024, 02:12 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • dragon3x
    >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
    by dragon3x
    Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
    that is still quite new, as it worked OK for some months until it failed.
    At the time I was not into power supply electronics; it was put
    aside and a new power supply installed inside the computer. Also at the time
    power supplies were half the price of today's.
    On the PCB there are a D339 and 7500B chips.
    I have found that schematics with these 2 chips (see included file).
    Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
    Some measurements,...
    06-05-2024, 03:34 PM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
