Samsung UE55NU7026K no image
  • yokoono
    • Apr 2010
    • 515
    Main BN41-02662A and panel CY-NN055HGLVCH.
    Does anyone have the software saved from this TV? I am especially interested in IC503 (25Q40).
    I saved the contents of the memory, I rewrote it but the TV does not turn on. I think the contents of the memory were saved incorrectly.
    Thank you in advance.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4543
    • Italy - Milan
    Re: Samsung UE55NU7026K no image
    Standby led emits some signals? If yes it's highly possible that your spi flash has no faults in it. have you checked sub voltages on mainboard? Power on signal circuitry (also on power board)? PSU voltages?
    • yokoono
      • Apr 2010
      • 515
      The TV started correctly, with backlight but no image. I suspected the panel. I saved the contents of the IC503 memory (25Q40) to be keep in the archive in the event of another repair. I did the rescue in circuit with ch341A. I deleted the memory and rewrote it with the saved software. The TV does not turn on. The left LED is off. Of course the contents of the memory were not saved correctly. To return to the initial state I need the contents of this memory.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4543
        • Italy - Milan
        Sorry i forgot the title, why to rewrite the memory?? It is not related to a panel defect!
        • yokoono
          • Apr 2010
          • 515
          The panel is compromised. I wanted to save the contents of the memories in case a repair is needed. To be archived. Unfortunately, he was saved wrong. I was wrong to try to save the contents with the memory in the circuit. I rewrote the memory with the same content and the TV does not turn on. It has 2 flash memories and an EMMC.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4543
            • Italy - Milan
            Ok saving the content but why loading it to the board? It's an unuseful risk, and also to avoid bad reading i always do a second reading and compare them in HxD program, also third time if is needed.
            • yokoono
              • Apr 2010
              • 515
              I made my mistake . I just want to bring the board back to its original state even if the panel is defective. I'll keep it for rehearsals.
              • yokoono
                • Apr 2010
                • 515
                Another code written on the main is BN94-12869G
                  09-07-2024, 05:50 AM
                • shlomim412
                  samsung ua55es6800 - no image
                  by shlomim412
                  hi
                  having problem with samsung ua55es6800
                  tv had backlight on, sound working - responds to the remote control but no image.
                  check tcon board - had 12v in but no other voltages present.
                  when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                  when leaving only left side connected - again no voltages and no image.
                  put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                  kept trying to block less pins on the left ribbon cable...
                  05-15-2024, 05:00 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
