CV59H-K32 remote control not working after flashing
  • Zibbo
    • Mar 2017
    • 203
    • Zimbabwe
    I have a CV59H-K32 motherboard that was stuck in standby, I downloaded a bin file from the internet and flashed the eeprom. The TV now works but the remote control no longer does.
    Is there a way I can use a hex editor to extract remote control codes from the old dump and inject them into the new dump?
  • Diah
    • Feb 2013
    • 6384
    Re: CV59H-K32 remote control not working after flashing
    NO.
    you can download other firmware to flash it again here are all firmware for yours boards
    • Zibbo
      • Mar 2017
      • 203
      • Zimbabwe
      Thank you very much Diah, however my board number is not on the list
      • Diah
        • Feb 2013
        • 6384
        all boards letter sharing same RC code ( remote.config). you my have the 1-flashing was not complete correctly or 2-your RC defect, or 3-the receiver on the boards.
        2&3 you can try universal RC or use android app on mobile have ir sender.
        • Zibbo
          • Mar 2017
          • 203
          • Zimbabwe
          Thanks, let me try to reflash. If it fails I will try to find another remote control
          • tmhobadcap
            Pioneer VSX-522-K remote control not working???
            by tmhobadcap
            I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
            At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
            12-24-2020, 01:44 AM
          • piipo
            Old Privileg 5.1 speakers remote control question
            by piipo
            Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
            09-18-2024, 01:55 AM
          • FedorovV
            MSI Alpha 15 B5EEK-237XRU Need BIOS working DUMP from a laptop, not from the site.
            by FedorovV
            MSI Alpha 15 B5EEK-237XRU SN:K2209N0193161
            Came without initialization. Before that, it was not under repair. With BIOS from the official website, there is a start Ok, after a while the fans gain speed and the laptop turns off.
            The cooling system is cleaned, the contact spot is good.
            I need a working dump from laptop to check.
            This is an original, not working dump....
            03-10-2024, 07:26 PM
          • dfear
            hitachi 75hl16t64u - not responding to remote control
            by dfear
            I have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
            It came in for a power issue which I have finally resolved by replacing the power supply.
            The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
            Anyone have a clue how to fix TV?
            FYI: I have checked the remote work s by pointing it at my camera on my phone....
            09-02-2024, 12:15 PM
          • unimatrix93
            Midea MD1001LF control board not working
            by unimatrix93
            I have this high powered microwave over that does not want to start.
            When I plug it in the mains power, the fan start up but the control panel does not work, no display only the stop button beeps when I press it.
            I checked main filter capacitors next to the PFC IC (TNY174) they are showing 328V and the IC drain pin is at the same voltage.
            The transformer has multiple outputs:
            3v3, -27V, -5V, -12V.
            Now when the fan is working I measure 17V on 3v3 pin and 5V when the fan stops and relay clicks. I guess...
            09-04-2024, 06:18 AM
