MSI Alpha 15 B5EEK-237XRU Need BIOS working DUMP from a laptop, not from the site.
  • FedorovV
    • Dec 2018
    • 5
    • RUSSIA
    MSI Alpha 15 B5EEK-237XRU SN:K2209N0193161
    Came without initialization. Before that, it was not under repair. With BIOS from the official website, there is a start Ok, after a while the fans gain speed and the laptop turns off.
    The cooling system is cleaned, the contact spot is good.
    I need a working dump from laptop to check.
    This is an original, not working dump.
  • JoWed
    Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
    by JoWed
    Hello Community,
    I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
    07-01-2025, 09:32 AM
  • TyMercer
    Can I flash a working BIOS from one computer to another of the same make, model, etc?
    by TyMercer
    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
    11-13-2025, 09:39 PM
  • cr4zychriss
    by cr4zychriss
    • Rebrand: PC Specialist
    11-14-2025, 04:04 PM
  • mkdj
    by mkdj
    Dear all,
    10-19-2025, 04:41 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
