Samsung UN65RU8000FXZA Led Driver Board
    • 21586
    Re: Samsung UN65RU8000FXZA Led Driver Board
    Originally posted by peterkos2
    Good day. Did you fix this problem?. I have something similar on the Samsung UE50RU7092 TV.
    Thank you for your response
    You have a different model,start a new thread please and list all boards in your tv like the OP has done at post #1 ,and include the make and model number in your thread title.
    • abbsour
      • Mar 2019
      • canada
      Hi Hink85,
      I have same problem with
      My un65ru8000f.Any luck with fixing yours?
      Thnx
      • nsolo15
        • Dec 2021
        • canada
        Hey,
        I picked up the same model TV and found that the panel board on the right side is causing the malfunction. I think I finally found the bad cap. It is C001. I'm just looking for the tools to remove the cap, but does anyone know the specs of this capacitor? Need to find out what to replace it with.
        Thanks.
        • Hink85
          • May 2019
          • 22
          You can remove it with a solder iron and copper braid, put flux on the copper and it will pull the solder in, or use a heat station. I bought a cheap one for around $70, you may want to use low temp solder and add it to lower the melting point.
          I don’t know the package size based off the part number but you can take a caliper and measure the cap size to reference it to the package sizes I listed in an earlier post. The bigger capacitors had less than 35V on them and the smaller packages I believe some were 100nF but maybe an 8V cap MLCC. Multi-layer ceramic capacitor, the larger caps maybe around 1uF
          • Hink85
            • May 2019
            • 22
            A lot of the caps were in parallel, so I thought I had found bad capacitors and after removing them, they were still good. I didn’t get mine fixed unfortunately.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • ohren
              Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
              by ohren
              I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
              I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
              The models launched in 2018 and 2019 respectively....
              09-08-2023, 05:24 PM
            • C152Heavy
              Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
              by C152Heavy
              Summary for TL-DR readers:
              • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
              • Have obtained Samsung schematic & service documents - Can upload if helpful.
              • Have read ALL applicable threads
              • C1818 and CP820 replaced as low hanging fruit
              • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
              • VCC pin (18) of PFC...
              01-11-2023, 02:53 PM
              09-07-2024, 05:50 AM
