Re: no backlight supply volts hisense ub50ec591uwt
i am confused .. are you repairing now 2 power boards at same time ?? how it come STB voltage not exist only if MB connected ??? sorry man i cant follow your points.. it make real headage
ud 901/902 check out ok by comparison with similar board using same fets
the psu pin STB has no volts on it until main board is plugged in so links with 1k resistors wont startLeave a comment:
when you do 2 jumper 1K ... the second one between STB to PWM2 ( orange) how much the volts read on the orange pin after the 1K ?? and before on STB pin. and are you sure no V on BL socket ??( you can disconnect the LED socket and measure )
BTW: i think you have over clock on the hot area.. this why the 16V show 20 ... UD901 &902 need to test them after the free them from the boardsLast edited by Diah; 08-05-2020, 06:29 AM.Leave a comment:
heres pics of print side psu in pic 3 you can see that the last 5 pins are not usedLast edited by jimbofz; 08-05-2020, 06:01 AM.Leave a comment:
show us clear photo of the back side of the PWBLeave a comment:
Pin 1, VCC can accept a voltage of 10V to 27V so the supply to the IC is fine.
Pin 2, Enable input is also fine at 2.4V so the IC is enabled.
Pin 16 is a 5.25V regulated supply internally generated from Vin and is the supply voltage for the circuitry inside the IC.
I would say that it looks like either the IC is faulty or any capacitor connected to pin 16 needs to be checked.
this tv has two led strings im wondering if there resistances at switch on are compared within this chip it would then fail to produce this voltage on pin 16 although all leds test fine perhaps theres a difference in the replacements i have fitted compared to the originals?Leave a comment:
keep the 1K jumper in place and make another 1K jumper between STB and PWM2 the BL socket should read voltage and may the BL come on.Leave a comment:
I would say that it looks like either the IC is faulty or any capacitor connected to pin 16 needs to be checked.Attached FilesLast edited by dick_barton; 08-05-2020, 04:06 AM.Leave a comment:
16 V read 16 ?
remember you told us it was 20 at STB and 19 at ON ?Leave a comment:
16v ok 12v ok , sadly still no bl voltsLeave a comment:
STB always read the same voltage as its provided by PSU
SW 3.5V are signal provided from MB to turn on the PSU 12 16V, the jumper will replace the MB actionLeave a comment:
i was told it just failed and the backlights all looked untouched ,if the psu was the wrong one you would assume that the main board would have a plug with missing lead also the main board does not have any spare sockets for any other plug ,so from this i assume its the correct psu .
the two pins with the 20v on, are joined on the print of the psu ,and i wonder why its not 16v as shown on psu , the 12v is ok shown as 12 v on psu.
if i unplug the main board and fit jumper between SW and STB surely the psu cant start up as both these pins read 0v at switch on and only recieve volts to turn on from main board ? or am i missing somethingLeave a comment:
While you are doing that test could you also check Pin16 of the LX2901. Votage should be a regulated 5.25VLeave a comment:
this is strange.. this TV had story before its come under your hand.. who knows if the PWB belong to it ???Leave a comment:
i know ,it isnt used on my 10 pin version of the psu panelLeave a comment:
by Superbee_dadHello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...01-24-2025, 11:51 PM -
by phuzzydayThis was my initial thread.. https://www.badcaps.net/forum/troubl...-m-at-wits-end
(All the Electrolytics are brand new.)
I started a new one, hope that's ok, because my question is different now! (Strangely enough, after I walked away for a few weeks, it stopped lighting up at all!!)
I am determined to fix this power supply because I have the skills to replace bad components, I just need to find out... -
by ojmcBackground:
- Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
- I replaced all 6 of the backlight LED strips with these replacements: amazon
- The TV worked again perfectly for ~2 weeks.
- After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
Assuming...7 Photos -
by BoardHoarderCurrently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
- Loading...
