LG50PC56 snow on screen
  • 24mech
    Badcaps Baby
    • Feb 2014
    • 103
    • United Kingdom
    Hi there I have been given a faulty tv that I (cost permitting) would like to fix as a bedroom TV the issue is as in the pictures snow or white noise on the screen no input connected when picture taken, has this issue been seen before? any help would be greatly appreciated thank you.
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: LG50PC56 snow on screen
    Bad solder joints on the big filtering inductors on both Y-SUS and Z-SUS boards cause some plurple tint on the image, but yours are way more severe, these photos are quite the poor angle and resolution, but the TV seems to be displaying correctly the menu, bright enough to not be Z-SUS failure.
    Open the TV and take measurings from the test points on the boards.
    There's a sticker on the panel on the inside, it shows which important voltages need to be at what value. VSUS(PSU), VA(PSU), -VY(Y-SUS), VSCN(Y-SUS), Z-BIAS(Z-SUS).
    • 24mech
      Badcaps Baby
      • Feb 2014
      • 103
      • United Kingdom
      I'll get some better pictures and try to play a video source to help with understanding my issue thank you for responding.
      • 24mech
        Badcaps Baby
        • Feb 2014
        • 103
        • United Kingdom
        I've uploaded some more pictures, I tried to play video source and all i got was the pictures attached no real image to see just white noise, thank you for your help.
        • Biruslapio
          • Nov 2013
          • 552
          • Brasil
          No real image? when you plugged in something into HDMI for example, only "no signal" was displayed?
          Whatever method you're using to resize your photos is ruining the picture quality.
          I sugest you remove the back cover, and start probing with a multimeter those voltages:
          If they're normal, within spec, next you would need to remove the boards from the TV and check for bad soldering on the inductors I mentioned.
          I've also never seen this issue before, if someone else has, they could just point the cause immediately.
          • wizard13
            Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
            by wizard13
            I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
            I have checked the forum and the available documentation but could not find a solution specific to my issue.
            • Brand & Model: Dynabook Satellite Pro C50D-B-100
            • Part Number (P/N): PYU13E-00C00PFR
            • Serial Number (S/N): 22028896H
            • System Configuration (SC): A1PYU13E1127
            • Motherboard Model: IP3_ACN16_MB_V21_20211222A
            • Power Input: DC 19V –
            02-28-2025, 02:43 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • cloudy
            HELP - Contrast/brightness issue with subtitles on screen
            by cloudy
            Hi everybody
            Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
            Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
            Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
            It occours both on ubuntu and windows...
            01-01-2023, 05:12 PM
          • ScHAmPi
            Samsung UE48JU7000 screen issue after backlight replacement
            by ScHAmPi
            Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
            I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
            07-15-2024, 05:41 AM
          • kilog
            Snow on screen and no start Do I have to replace my CF53-MK2
            by kilog
            Hello friends,
            Last week when I tryed to start my CF53-MK2 it just stop starting
            and when it starts it displays snow and dansing and coloured lines on the sreeen as you can see in the attached video.
            Some time it may show the startup Bios screen for a 3 to 10 seconds and then immediatly starts to disply snow and coloured lines.
            I tested the RAM it is correct.
            I tried to hook the machine on a HDMI screen, nothing.
            I am not sure that the computer goes far to be able to show anything on an additional monitor.
            Please I need your...
            09-27-2023, 08:00 AM
