Toshiba 49L310U screen half white half black
  • cynfeld5
    • Jul 2020
    • usa
    I'm trying to repair my son's TV by following several Youtube videos. Original problem was no picture but there was an image if you shine a flashlight at an angle. There was audio but there were also no backlights. I replaced several LED strips and after reassembling the TV they worked. When I powered up the set there is a brief flash of light on the screen but no picture or image. Thinking I had incorrectly inserted the data ribbons from the T-con into the panel boards, I tried removing and replacing the two ribbons. Now when I power up I get a screen that is half white and half black (or dark). I've tried this a few times and end up with either no picture at all or the half screens.
    I would greatly appreciate anyone's input on what I might be dealing with at this point. I did replace the Power Supply board first before the LED strips so I'm in for a bit of money already.
    Thanks to everyone for any suggestions.
  • nomoresonys
    • 12331
    • U.S.
    Re: Toshiba 49L310U screen half white half black
    Check for around 12 volts on each side of tcon fuse, negative probe ob metal/chassis back, positive probe on each side of fuse, to see if that section is still ok.
    • Raulnn
      TD Systems K50DLG12US half black and half white screen
      by Raulnn
      good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
      By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
      01-20-2024, 04:49 PM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • harp
      White screen repairs
      by harp
      To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
      Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
      On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
      05-13-2024, 03:43 AM
    • Megan0
      Sharp LC-70UD1U Half screen Normal half screen is white
      by Megan0
      My Sharp LC-70UD1U Screen is black and flashing, "I attached the video"
      Well, I opened the back cover and as you can see in the picture, I unplugged 2 L (left) ribbon, TV turned ON, but half of screen (Right) is normal, and the other side (Left) is white. I continued to test...
      Result:
      I swapped the ribbons L<-->R = Blinking 2x power light, 5x timer light
      Unplugged 2 R Plug 2 L = Blinking 2x power light, 5x timer light
      Unplugged 2 L Plug 2 R = Blinking 2x power light, 5x timer light
      Only in the first test, where I did not
      01-19-2022, 11:20 AM
    • buchman
      Toshiba 49U7750VQ HALF SCREEN DARK
      by buchman
      I opened the TV and tested each LED strip, and they all work fine. Checked voltage on the CN400 plug that goes to the LEDs and LED1 I had 62.6 volts and on LED2 I had 38 volts. How much should it be? what can be the cause? On the back of the board there is a Transistor (I think), the part number is BR10T100. What should be the reading? I tested it and had a Short between the 2 small legs. is that OK?...
      10-14-2025, 06:43 AM
