LED screen half white half black
  • cynfeld5
    • Jul 2020
    • usa
    I'm trying to repair my son's TV by following several Youtube videos. Original problem was no picture but there was an image if you shine a flashlight at an angle. There was audio but there were also no backlights. I replaced several LED strips and after reassembling the TV they worked. When I powered up the set there is a brief flash of light on the screen but no picture or image. Thinking I had incorrectly inserted the data ribbons from the T-con into the panel boards, I tried removing and replacing the two ribbons. Now when I power up I get a screen that is half white and half black (or dark). I've tried this a few times and end up with either no picture at all or the half screens.
    I would greatly appreciate anyone's input on what I might be dealing with at this point. I did replace the Power Supply board first before the LED strips so I'm in for a bit of money already.
    The set is a Toshiba 49L310U.
    Thanks to everyone for any suggestions.
  • ivtec
    • Dec 2008
    • 1967
    Re: LED screen half white half black
    Try to clean ribbons on Tcon board or replace Tcon board.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Can you post pictures of your circuit boards and add them as attachments.
      What dc voltage do you have on each side of the tcon fuse?
      • Raulnn
        TD Systems K50DLG12US half black and half white screen
        by Raulnn
        good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
        By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
        01-20-2024, 04:49 PM
      • hcinne
        Dell G15 ryzen edition black screen 2 amber 1 white
        by hcinne
        I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
        07-23-2024, 07:56 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • maneatingmonkey
        LED LCD TV Screen Half Black, Half White - Panasonic TH-65AX800A
        by maneatingmonkey
        Any idea what could be causing the left half of the screen to be completely black and the right half completely white?
        No picture from any input or OSD. The audio, however, works fine. Also, the backlight changes intensity along with the input feed.
        I've tested the voltages on all the marked test points I could find and everything reads OK.
        I've tried applying both heat and pressure to the tabs connecting the panel to the buffer boards to no effect.
        Unplugging the white ribbon cables going into the 2 buffer boards on the black half of...
        02-28-2020, 07:22 PM
      • VcemPzd
        Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
        by VcemPzd
        Hello everyone !
        My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
        04-28-2025, 10:14 AM
