samsung 40f5000 voltage very high
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    Hello i have a samsung 40f5000 led tv, when i opened to the back light i found some burnt led and the white plastic all burnt, so am asking because when i test the back light voltage i got 332v and the back light is haven 91 leds, i stand to be corrected , 3v x 91 =273v , but someone said the voltage is meant to be high without load. i need help
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: samsung 40f5000 voltage very high
    It's not unusual for the led voltage to be higher when the leds are open circuit and the set is powered up. The voltage often initially peaks and then drops back.
    • karatzdi
      Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
      by karatzdi
      I know some might say... just buy another one. Sell it as parts..!
      So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
      Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
      Spent some time downloading the Service...
      06-11-2024, 08:38 AM
      09-07-2024, 05:50 AM
    • DynaxSC
      Extreme High Current & Low Voltage Short Killer ??
      by DynaxSC
      Hi Folks
      I'm looking for a extreme high current short killer solution for a reasonable cost.
      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
      After taking off the socket, the shorts dissappear again.
      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
      10-15-2024, 10:13 AM
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
