Looking for a standalone tuner
  • Maxxarcade
    • Jul 2006
    • 973
    Where can I buy a standalone tuner that will decode ATSC and QAM? I'm looking for one that can output 480P, 720P, or 1080i.
    All I can find on Ebay are USB or other PC based tuners. I need something that will work with a plasma monitor which supports component or VGA input. Why is it so hard to find a box similar to what the cable company uses for digital stuff?
    I'd also like it to be small, since the TV is wall mounted, and I don't want a shelf sticking way out.
  • tmwalsh
    • Jan 2009
    • 119
    Re: Looking for a standalone tuner
    All over the place ...
    here's one:
    http://www.barrel-of-monkeys.com/gra...2/dct612.shtml
    their list:
    http://www.barrel-of-monkeys.com/gra...ers-main.shtml
    I think avsforum.com has a thread about standalone tuners.
    tom
    • Maxxarcade
      • Jul 2006
      • 973
      here's one:
      their list:
      tom
      Thanks, for some reason I couldn't find anything like that by using a search. And I sure wouldn't have thought to look at a place called Barrel Of Monkeys :-)
      That's exactly what i need.
      • bluto
        • Oct 2007
        • 560
        Look on ebay for a Samsung DTB-H260F. You might have to replace a few caps though...
        https://www.badcaps.net/forum/showthread.php?t=7804
        • DXseekerMO
          Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
          by DXseekerMO
          I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
          As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
          09-15-2021, 05:15 PM
        • Mark R
          Does Changing Out Caps In A Tuner Effect FM Reception
          by Mark R
          "TQ" Subject at hand is a Marantz 120 tuner. The tuner lit up but no output. Recapped the entire unit. Before it was working fine tuning in Stereo and Mono. Now it just about tunes Stereo and some of the mono stations are weak. Nothing else was changed. When you do hit a stereo station the stereo lamp will come on but flickers as it's trying to hold the MPX signal.
          I don't see how bringing the unit back with new caps checked by my Sencore LC103 would effect the FM section. Every Value is as it was from the factory?
          Any Thoughts?
          06-11-2024, 07:04 PM
        • Ierwin
          55PFL4908K/12 DVB-S tuner not available
          by Ierwin
          I have a rather strange problem with this Philips I just repaired.
          The set came with startup problems, I checked the PSU, found some puffed caps, replaced them and now it is starting perfectly.
          According to the philips website this tv should be equipped with a tripple tuner.
          However there is no option to scan for satellite channels in the menu.
          It only shows the option to search for DVB-T or DVB-C channels.
          The set is equiped with the F-type connector in the back so to me it looks like it is indeed equipped with a Sat tuner....
          11-10-2023, 12:05 PM
        • Mark R
          Marantz Model 120 Tuner Craziness I am Stumped!
          by Mark R
          My Marantz 120 Tuner stopped receiving Stereo signals. It works fine other then Stereo. I have a fully loaded shop here with all test equipment except and RF signal Generator.
          I get great reception on FM so I have used that signal troubleshoot. I have been all over the MPX board and replaced all caps. Also the entire power supply caps were replaced.
          All Voltages on the MPX board are good... all Transistors Good...All Diodes Good and other components.
          The stereo lamp is good as I powered it up and it lights. The signal flow to that lamp is unbelievably...
          10-20-2023, 01:25 PM
        • mechguy
          Centronics ZAT502HD ATSC Set Top Box
          by mechguy
          I watch some basic TV using an ATSC tuner set top box which outputs HDMI to my LCD TV. The brand is Centronics, which seems like a fairly low cost (ie cheaply made) product. The UI is a bit crude looking compared to what I've seen on TVs that have the ATSC tuner built in (but it works!). Anyway, the set top box has always had an odd behaviour, which is that turning the device on using the remote would sometimes not "stick", that is, it would turn on momentarily and then immediately turn off. It didn't do this all the time, but it did this randomly since I've had it, which is 2009. Recently...
          05-17-2024, 12:44 PM
