Vestel 50 inch LED backlight, Sound, No picture.
  • Diah
    • Feb 2013
    • 6460
    Re: Vestel 50 inch LED backlight, Sound, No picture.
    Originally posted by sordids999
    Tcon ribbon connected
    VGH 0.10V
    VGL 0.00V
    VSS 0.10V
    AVDD 0.27V
    AGIN 0.00
    Tcon ribbon disconnected
    VGH 1.21V
    VGL 0.05V
    VSS 0.00V
    AVDD 1.31V
    AGIN 0.00V
    Any reason why theres nothing on the screen when you disconnect one ribbon at a time?
    Normally you get a white screen each side
    LCD function depend on T-CON pulse signal not voltage,, if there are no pulse nothings will displaying on the screen
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • maneatingmonkey
      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
      by maneatingmonkey
      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
      03-27-2024, 07:17 AM
    • Raulnn
      Ansonic 32HD1 Vestel 17IPS11 17mb55 no Sound, no backlight, no images
      by Raulnn
      Hello! I am new to electronics, and this forum is fantastic. I have the following problem, I have an Ansonic 32HD1 tv, a generic brand from Vestel, with a 17IPS11-R4 power supply and main 17mb55.
      The tv has no backlight, but it also has no image and sound. when it turns on the standby light blinks several times, and there is a very short flash of the backlight, as if it wanted to start, but it does not start. I have measured the voltage on the red wire of the backlight, as you have seen on the forum, and in standby it has 30v, and when it turns on it goes up to 100v and slowly drops...
      11-15-2022, 03:02 PM
